Room Acoustics & Mods A place to discuss measuring and modifying room Acoustics for better sound
diy Diffusors
diy Diffusors
Thread Tools
Old 13th January 2021, 07:34 PM   #11
audiorasp is offline audiorasp
diy Diffusors
Default Argen
Is the Argen Sound Diffusers 101 site still active? I tried to download the plans but got a message that "the mailing list is not active".
Thanks,
George
Old 13th January 2021, 08:17 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
diy Diffusors
I just checked, i get the same error.
I may have downloaded all the plans. If so i will find them (have to go downstairs and turn the server back on — had a brown out last night) i will post them.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 13th January 2021, 08:29 PM   #13
diy Diffusors
Thanks Dave!
Old 14th January 2021, 12:46 PM   #14
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
Hello,
Just got the AudioTool app installed on my android tablet. Got the Dayton iMM-6 microphone too. Now waiting for some cables.
I will probably get Caruso iso bond WLG 045 panels at Don audio in Germany if they are still business.
With these i will make bass traps and i wanna add a panel 8 inches (200 mm) thick and the seize of two 50 inch TV screen next to each other behind my listening sofa starting at the height where the sofa ends so 3 feet. Because there is a BIG window behind my listening position i cannot install to much panel there. The only thing i can do is attach a 8 feet by 2 feet panel to the ceiling at about 1 feet ( because of windowsill)from the window and move it downwards when i listen music.
With acousticmodelling.com software it shows better ( a nice rising curve with no valleys or hills) so probably i need some hardboard to close in on the backside.
The iso bond seems very easy to work with much more user friendly then those fibre based material .
If Don audio is still in business and replies me i will order them there if not i will find another dealer.
Greetings, Eduard
Old 18th January 2021, 03:26 AM   #15
frugal-phile(tm)
planet10's Avatar
diy Diffusors
http://p10hifi.net/forum/DIYdiffusers.zip
  Reply to this post
diy DiffusorsHide this!Advertise here!
Thread Tools
Placement of Diffusors POOH Multi-Way 30 18th February 2017 03:22 AM
Wide polar pattern speakers via Diffusors noodle_snacks Multi-Way 6 11th May 2012 08:47 PM
Diffusors in enclosures? walker Multi-Way 6 29th November 2001 09:36 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
