Room Acoustics & Mods A place to discuss measuring and modifying room Acoustics for better sound
Ambience tweeters using small BMR drivers
Old 5th April 2019, 04:31 AM   #51
frangus is offline frangus  Australia
Hi Bill
Have you made any changes to these? Are they still 5db down from the main signal? Might give this a try tonight with some spare drivers
I have the old non-HD minidsp 2x4 with a limit of 7.5msec (if I recall correctly) however I can run the ambient drivers several metres behind and above my couch. Hopefully that will do the trick. Will also play with the bandpass limits on both ends of the spectrum
Old 5th April 2019, 09:52 PM   #52
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
I've got the delay up to about 25msec now (I think it was). Haven't measured the level in a while, set it by ear most recently. But probably still at about 5dB down I'd guess. When you measure the ambient level, you have to use a long window since the ambient arrivals will be spread out more in time than when you use the usual ~4msec window usually used in-room.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 14th April 2019, 12:39 AM   #53
Well I didn’t have great success with this and probably due to the 7.5ms limit of the minidsp. I did try the haffler wiriing with a 200-3000hz bandpass filter and that has been the most successful ambience experiment so far. Amazingly effective!
I’ve ordered a minidsp HD and will try again with a 25msec delay
Cheers
Old 14th April 2019, 02:25 AM   #54
bwaslo's Avatar
Sorry it didn't work for you frangus. Are you reflecting the NBR driver off the wall and ceiling too?
Old 15th April 2019, 12:11 PM   #55
Bill, my testing was crude, using tiny speakers instead of BMR drivers. This and the fact that my minidsp is limited to 7.5ms is the issue I believe. Iíll do further testing once my new minidsp arrives and get back to you
Ambience tweeters using small BMR driversHide this!Advertise here!
Small footprint SUB using multiple small drivers FredrikC Subwoofers 5 29th August 2010 05:01 AM
Small footprint SUB using multiple small drivers FredrikC Subwoofers 0 25th August 2010 08:12 PM
Rear mounted ambience drivers, opinions? ptwining Multi-Way 5 20th December 2007 04:41 PM
Ambience tweeters? Audiophilenoob Multi-Way 13 20th June 2005 02:38 AM
best tweeters in small size maxxx Multi-Way 1 7th March 2004 04:53 AM
Copyright ©1999-2019 diyAudio
