Room Acoustics & Mods A place to discuss measuring and modifying room Acoustics for better sound
Acoustics of corners
Old 28th January 2018, 06:08 PM   #111
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by scottjoplin View Post
prefer it.
"it", what is "it"? My point is that there can't be any "pressurization" so what exactly is "it" that you don't like?
Earl Geddes Gedlee Website
Old 28th January 2018, 06:13 PM   #112
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
And my point is that there is a degree of pressurisation as the cone moves out from a sealed box in my not quite sealed room. It's a small room, I've used both sealed and open baffle and it definitely feels different on my ears and feels like pressure, what else could it be?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 28th January 2018, 06:29 PM   #113
gedlee's Avatar
It's not static pressure, I hope we can agree to that. What I find most people dislike in bass in rooms is a strong mode which creates a booming effect and maybe a feeling of "pressurization". This will not occur for a dipole if the mode is low enough in frequency, only a monopole will excite it. The solution is to EQ the room better so that this doesn't happen. The dipole can never be EQ'd to achieve the same response as a monopole in a small room, so a dipole not not really a solution, its a band-aid.
Old 28th January 2018, 06:40 PM   #114
Yes of course.
This sounds like what I've experienced
Do you mean the same low frequency response of a monopole, say, below approx 40Hz. I appreciate a dipole isn't a solution to room modes, is that what you mean?
Old 28th January 2018, 06:54 PM   #115
gedlee's Avatar
I mean that dipole just cannot extend the bass to lower frequencies in a small room the way a monopole can. The bad rep that monopoles get is because they are not used properly and not because dipole are superior. My room only has monopoles and it has a nice smooth LF response down to 20 Hz - no dipole can do that. Of course It's not trivial to setup, but I get annoyed by implications that dipoles are somehow inherently superior because people have only heard inferior monopole setups.
Old 28th January 2018, 07:07 PM   #116
Gotcha, I can get down to 32Hz quite comfortably, I'm experimenting with IB for the last octave. Dipoles are a compromise, but quite a good simple one if you can accommodate them. Room modes are still a slight pain in the backside though, they annoy me (a bit)
Old 1st February 2018, 08:56 AM   #117
DorinD is offline DorinD  Romania
DorinD's Avatar
Got L=4.7mH, R=2 ohm, C=470uF and did another set of measurements:
1. RLC_shunt vs. Short-circuit vs. No absorber
2. RLC_shunt vs. Short-circuit (for better visibility)
I would say that both short-circuit or RLC shunt look better than no absorber. And RLC shunt has a little margin over short-circuit as two dips look better. This is only measurement, I will go on listening the RLC thing too see if I can hear a difference.
It's never too late having a happy childhood
http://www.homebuilthifi.com/project/5604
Old 2nd February 2018, 03:08 PM   #118
jlo is offline jlo  France
Back to my first question :
Originally Posted by jlo View Post
we know that corners are places where all low frequency modes are present with max pressure and no velocity. For this reason, many people (and many books) say that basstraps are preferably placed in corners. This is also often said for fibrous materials (despite no velocity in corners). For sure, at opposite corner, the effect will be heard. But at listening place ?
I think that found one explanation after a nice discussion with somebody who was active in the development of the AVAA from PSI : this active absorber is a nice tool to understand some acoustics because you can easily compare and measure when switching it on/off.
My explanation : when you place this absorber or a passive resonator or absorbant in a corner (ie anything that has some acoustic inluence in low frequencies), this "absorber" can be considered as a re-radiating item. Generally its dimensions are smaller than the low frequencies wavelengths concerned. Due to the small dimensions, the directivity of the re-radiation is wide and so will influence and distord the original soundfield everywhere in the room.
Does this make sense ?
jl ohl
ohl about audio
Old 2nd February 2018, 03:21 PM   #119
gedlee's Avatar
At low frequencies in a small room one cannot talk about "directivity, because waves can only follow the modal pattern being excited, so no, that explanation does not make sense.
Old 2nd February 2018, 08:40 PM   #120
Yes but the modal pattern is changed due to the change of impedance at the corner.
jl ohl
ohl about audio
Acoustics of cornersHide this!Advertise here!
Q acoustics 2020i vs Boston Acoustics A26 rajeshnitk Full Range 0 26th September 2016 04:43 PM
Help on choosing cabinets for corners tilroh Full Range 24 29th June 2013 12:16 PM
No Room Corners Tamaki Full Range 14 25th September 2010 10:29 PM
