Room Acoustics & Mods A place to discuss measuring and modifying room Acoustics for better sound
Making easy DIY "Depot" sound Diffuser panels, step by step
Old 10th July 2017, 11:29 PM   #121
emailtim is offline emailtim  United States
Originally Posted by bwaslo View Post
They are exactly the multiples of the given wood dimensions. The model was optimized restricting to such dimensions. I think the AFMG screen of this one is the attached (not sure, but it's at least a close one)
It is not a mathematically derived type diffusor like an MLS or RPG type, it is an empirically optimized/analyzed type (which can be just as effective, by the way).
What I can glean from the bits and pieces, the LeanFuser is a factor of 5 equal units high, each unit being 10 mm (of which they only use levels 0, 3, 4 and 5). Tim mentioned to make the imperial version of the LeanFuser, it would be acceptable to use 1/2" (approx 12.5mm) and that it actually worked better than the metric 10mm version.
Your version appears to be approximately 2X the LeanFuser unit height (or 2 x 10mm) given the available material depths (with a different height sequence).
LeanFuser - Yours (calculated from selected material)
50mm - 98.4mm (1.5" + .3" + (3 x .7"))
40mm - 80.9mm (1.5" + .3" + (2 x .7"))
30mm - 63.3mm (1.5" + .3" + (1 x .7"))
none - 45.7mm (1.5" + .3")
none - none
0mm - 0mm
Is this the correct interpretation (scaled by a unit factor of 2 and different height sequence) ?
LeanFuser Height Unit Sequence - 0, 4, 5, 3, 5, 4, 0
Your Height Unit Sequence - 0, 2, 3, 4, 2, 5, 0, 0, 5, 2, 4, 3, 2, 0
TIA
P.S. Debating on trying this one or a QRDude painted EPS version to experiment with.
Old 25th July 2017, 04:19 AM   #122
MFagains is offline MFagains  United States
Originally Posted by emailtim View Post
The Diffuser Fabrication document stated that when repeating the pattern, the mounting depth needs to be varied to avoid "periodicity" (which I would assume to be similar to a comb filter effect). The center one could be slightly raised more than the flanking 2.]
Hello All;
being that I only have room for 2 diffusers, will "periodicity" be an issue with them side by side?
MF
Old 25th July 2017, 06:10 AM   #123
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
make them not be the same distance from the listening chair or from either speaker
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 25th July 2017, 04:52 PM   #124
Thank you Sir.....
Old 21st November 2017, 09:00 PM   #125
Cambe is offline Cambe
bwaslo,
My friend Irshad and I recently completed a pair of diffusers based on your design. We both are very impressed with the outcome of this project.
Thank you for sharing this with us.
I have attached pictures of the diffusers in Irshads listening room of the front and back walls. If their any other suggestions or improvements we can make let us know.
Old 21st November 2017, 09:17 PM   #126
Sorry, I don't know why the pictures came out upside down.
Old 22nd November 2017, 01:37 AM   #127
bwaslo's Avatar
Thanks Cambe. Those look nice in there, looks like a good room.
Old 15th December 2017, 11:05 PM   #128
rickmcinnis is offline rickmcinnis  United States
Finally going to make some of these.
I need to hang them so I will hear how the 2 inch foam board works.
I would like to use the same size board for everything - instead of the plywood on furring strips a 12.7 x 96 inches piece and the other pieces using 2.34 x 96 inches but using the two inches thick material.
Would this extra depth upset everything?
Old 15th December 2017, 11:28 PM   #129
bwaslo's Avatar
Don't know. Probably not a problem, is my guess (just a guess though)
Old 20th December 2017, 05:07 PM   #130
straight8s is offline straight8s  Canada
Great tutorial, thanks for sharing your methods.
Making easy DIY "Depot" sound Diffuser panels, step by stepHide this!Advertise here!
EL166 "built in baffle step compensation" sreten Multi-Way 3 23rd April 2012 12:45 AM
Home built 1" dome tweeters, with step-by-step pics flyingtele Multi-Way 3 3rd April 2011 09:11 PM
Hybrid amp Aloia GY-50 "a step beyond of" Stee Solid State 12 27th January 2011 07:19 AM
DIY RPG "skyline" diffuser panel Magnetmaz Everything Else 8 6th March 2009 12:58 AM
Need help using "Edge" to design Baffle Step Correction Circuit please. G Multi-Way 5 3rd July 2004 10:49 PM
