Room Acoustics & Mods A place to discuss measuring and modifying room Acoustics for better sound
Controlled vs wide dispersion in a normal living room environment..
Old 24th February 2019, 09:40 PM   #781
Adhoc1 is offline Adhoc1
Placing sofas and speakers in front of a large concave surface like the bay window would be asking for trouble, there is a high risc of focusing all reflection within that concave area to one spot. -Similar to a parabolic antenna, the opposite of a simple polycylindrical diffuser.
Old 24th February 2019, 10:35 PM   #782
martyh is offline martyh  United States
Originally Posted by Adhoc1 View Post
Placing sofas and speakers in front of a large concave surface...
True but I think very easy to solve. Easy way is window treatment another possibility would be panels on barn door hardware that could close at the wall line. They might even be made as a slim diffusers.
Old 25th February 2019, 04:59 PM   #783
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Originally Posted by gedlee View Post
What I noticed from the drawings and descriptions shown above is that many of you are dealing with highly constrained conditions that will seriously limit the end result.
Yes. I've largely removed the room from the equation by listening nearfield, I don't think there is any going back for me, and having the speakers and listening position near walls appears to produce largely insurmountable problems.
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 26th February 2019, 09:31 PM   #784
Bicicletta is offline Bicicletta  Europe
Originally Posted by Juhazi View Post
Great.
Love for the matter and talented teacher.
That's gold.
Old 28th February 2019, 07:26 PM   #785
kivitel is offline kivitel  United States
Earl, long time listener first time caller. The dilemma faced by many people listening in small rooms is that the tighter directivity is conventionally accomplished with larger speakers - bigger direct radiators, which are directive through one mechanism, and large waveguides, which are directive due to another.
For fun, I have been designing a dodecahedral omnidirectional speaker using small full-range units. Using 12 units makes up for the low output of these drivers somewhat, and although an omnidirectional high frequency source has some benefits, limiting early reflections is not one of them. The units I am using are 2" BMRs with outstanding wide dispersion into the top octave.
My question is this - do you think there is any merit to narrowing directivity by using sound absorption materials close to the sound source?
To illustrate my suggestion, imagine a 5" sphere with an array of 12 tiny drivers on it (what I am working on.) This source can achieve acceptable sound from 300hz on up. If this array was placed in a 1' diameter cylinder with one open end, lined with acoustic absorbing materials (which are highly effective at these frequencies) do you think the sound could be aimed at the listener? Sort of like an inverse shotgun microphone.
Thanks for your contributions to the hobby over the years, and especially for linking the Griesinger paper on speaker imaging.
Old 22nd March 2019, 03:29 PM   #786
gedlee is offline gedlee  United States
gedlee's Avatar
The way that you describe it, I don;t think that it would work, but certainly one could use the shotgun mic approach in reverse to create a high directivity beam over a limited bandwidth. But it would still be big - at least in one dimension.
Earl Geddes Gedlee Website
Old 26th March 2019, 05:28 AM   #787
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
yes, it is the best way to get accurate reproduction.
A more narrow dispersion speaker can help effectively extend the near field distance .... but, yes, near-field removes the room significantly.
THx-RNMarsh
Old 1st April 2019, 01:31 AM   #788
33Polkhigh is offline 33Polkhigh  United States
I used to listen near field before I knew anything about speakers. I think most people will gravitate toward a flat response at listening position regardless of speaker or room. Probably for most people removing the room will sound better. So bigger baffles and more directional speakers. But in a large enough room theres something to be gained from late reflections.
Directional sound is more intense, so as the speaker becomes more directional it should probably have less overall energy. A lot speakers have a baffle step right around cone break up and the combination can sound shouty. So the speaker and room need to work together to a flat overall power response.
Audiophile Music Collection
Controlled vs wide dispersion in a normal living room environment..Hide this!Advertise here!
Ultra-wide dispersion drivers? nonsuchpro Multi-Way 30 27th August 2012 11:41 PM
Best horn for 1" throat HF driver with wide dispersion and flat responce? cka3o4nuk Multi-Way 4 13th May 2012 02:30 AM
Wide dispersion speakers using full (wide) range drivers ozziozzi Full Range 1 28th December 2008 06:13 AM
An idea for a wide dispersion ESL jerko Planars & Exotics 25 29th November 2007 02:16 PM
Sub placement to counter wide dispersion? kyrie48 Subwoofers 3 20th September 2007 04:33 AM
Copyright ©1999-2019 diyAudio
