Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 1st May 2014, 04:01 AM   #191
quanghao is offline quanghao  Viet Nam
Send a message via Yahoo to quanghao Super V/i converted (LL1684 )
Originally Posted by linuxfan View Post
Another technical question please:
I see on the Neutrik XLR socket that the lower mounting hole is electrically connected to pin 1,
so when the Neutrik is attached to the rear chassis with a screw, pin 1 is then connected to the chassis -
that's all fine and correct for balanced output connections ...
... but on the PCB pin 1 of the XLR socket is also connected to RCA ground - thus RCA ground is also (permanently) connected to the chassis.
I thought that unbalanced outputs were supposed to have floating grounds. Is this correct ??
please see image for your conect GND and RCA out
The Best DAC is no DAC http://www.audiodesignguide.com/DSC2/index.html
ES9038PRO: http://quanghao.com/
Old 1st May 2014, 04:28 AM   #192
linuxfan is offline linuxfan  Australia
Yes, I see the correct jumper-connections at J1 and J2 for RCA output, but my question remains:
the RCA ground is permanently connected to chassis via pin 1 (and the lower mounting screw) of the Neutrik socket.
Is it correct to have RCA ground to chassis?
Old 1st May 2014, 04:34 AM   #193
HI!
pin 1 of Neutrik, it is GND , only conec to the GND of DAC
You not connect direct to Earth of Chassis.
Please conect GND of DAC to Earth of Chassis.
That i see your question ??
thanks
Old 1st May 2014, 07:21 AM   #194
Sorry, I'm not understanding you. As I read your comments, they seem to contradict. Maybe words fail.
OK, this makes sense to me, but it doesn't agree with what I see on the Neutrik connector; photo attached.
There's a small metal bracket which connects pin 1 to the inside of the mounting hole. Once a screw is inserted from the outside of the chassis, a connection will be made between chassis and pin 1.
Old 1st May 2014, 08:09 AM   #195
MattMax is offline MattMax  Netherlands
Originally Posted by audiodesign View Post
Are you using un-balanced output on RCA ?
The LL1684 output stage give at 0dB a standard 2Vrms so probably your amplifier cannot be used without a pre-ampl.
I am using the balanced output of the LL1684 output stage. What would be the best approach in this case? Just using the active output or is there a way I can still keep the LL1684 output stage combined with an active stage?
Thanks.
Old 3rd May 2014, 08:15 PM   #196
palmito is offline palmito  United States
palmito's Avatar
Default Got the boards!
Thank you Quanghao, they were just delivered by the post office! They look fantastic and will definitely look better than the spaghetti of wires I currently have...
Also noticed some things where soldered, so not strictly a bare board!
Two questions:
1) Repost from before, and I know it's been answered before: can we use a 2.2uF in the C4 position?
2) Is there a mechanical drawing for the xlr/rca connectors in the back (to use it as a template to cut holes in the case). I know I'm being lazy, but if it exists...
Thanks again.
Old 4th May 2014, 12:08 AM   #197
[QUOTE=palmito;3914779]Thank you Quanghao, they were just delivered by the post office! They look fantastic and will definitely look better than the spaghetti of wires I currently have...
Two questions:
yes C4 and C9 you can use cap : 1uf to 22uF MKP, so no need use cap = 22uF OS-con
no , you can not us it!
thanks quanghao
Old 4th May 2014, 12:35 AM   #198
palmito's Avatar
Thanks for your hard work Quanghao, this board was a great idea.
Old 4th May 2014, 01:52 PM   #199
Thank you for trusting me!
This PCB you can use with Jensen transformers, see image below PCB!
again thank you!
quanghao
Old 4th May 2014, 02:02 PM   #200
palmito's Avatar
I was going to ask about that, I notice it says "JT-11SS-DLCF" and was going to ask if this was another transformer. Nice extra functionality!
Super V/i converted (LL1684 )Hide this!Advertise here!
2x LL1684 FS yammy1688 Swap Meet 3 1st December 2014 11:56 PM
Can BR boxes be converted to TL? mikan Multi-Way 7 9th May 2006 10:58 AM
Another converted to dipole Mentero Multi-Way 24 7th January 2004 10:32 PM
Can A CD-Rom be converted to a transport? JZatopa Parts 8 29th May 2003 10:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
