DAC-END R (ES9018) full assembled board - version 2
super V/I converter with LL 1684
Hello, I have doubts about super v / i converter with LL 1684 if it can equip my power amplifiers, there's only 2 volts at the end of the output. I have a Holton hpanvx 300 r2, and hpanvx 500 r1 in paralell in each cabinet, will super converter with LL 1684 be able to make enough output voltage for my amps.
I hope someone here can help me.
Parallel amps
I drive an amp and a subwoofer (class d amp inside most likely) in parallel from the output of my LL1684s. The amp is 100kohm input , however, I don't know what the input impediance of the subwoofer is. Using no preamp, direct out to transformers of a buffalo iiise.
1. adeveza: DAC module + amanero + output stage + transformer (Complete Set: Item 6)
2. papapew: DAC module + amanero + output stage + transformer + chassis
3. smokingdog: DAC module + output stage
4. gde3: DAC module + amanero + transformer
5. villanueva: DAC module + amanero + output stage + transformer (item6)
6. MattMax: output stage only
7. CAAD: output stage only
8. Blackberry output stage only.
9. Mas Penk: DAC module + amanero + output stage + transformer + chassis
10. rade95: output stage + chassis
11. vmoreau : DAC Module
12. Removed
13. sandor: Complete DAC without output stage (option 6 without option 2)
14. Erlend Sæterdal: Output stage only.
15. Colesey : complete dac (item 6) in silver please
16. claudio52: Output stage only
17. Nick F: Complete DAC (item 6)
18. xtomm: output stage onl
19. brgds: DAC + output stage + amanero
20. danny_66: output stage only
21. anjogi: amanero + DAC + output stage + transformer
22. CaféNoir: DAC module + amanero + output stage
23. Jazzbear: DAC module + output stage + transformer
24. frankwilker: DAC module + Amanero module
25. NKL: DAC module + Amanero module+output stage+transformer
26. PeterKD: complete DAC (item 6)
27. rredline: Output stage only
28. schallundrauch: complete DAC (item 6)
29. Stenachio: Complete DAC without output stage (option 6 without option 2)
30. ervstil: DAC module + Amanero
B.R Christian
12. Removed
17. Nick F: Complete DAC exclude output stage (item 6 - item 2)
12. Removed
24. frankwilker: DAC module + Amanero module + output stage
OK, let me nervously join this GB for output stage only ...
... postition 12 (edbk) withdrew from the GB, so I will slip all numbers up, and join at position 30.
8. Blackberry: output stage only.
11. vmoreau: DAC Module
12. sandor: Complete DAC without output stage (option 6 without option 2)
13. Erlend Sæterdal: Output stage only.
14. Colesey: complete dac (item 6) in silver please
15. claudio52: Output stage only
16. Nick F: Complete DAC exclude output stage (item 6 - item 2)
17. xtomm: output stage only
18. brgds: DAC + output stage + amanero
19. danny_66: output stage only
20. anjogi: amanero + DAC + output stage + transformer
21. CaféNoir: DAC module + amanero + output stage
22. Jazzbear: DAC module + output stage + transformer
23. frankwilker: DAC module + Amanero module + output stage
24. NKL: DAC module + Amanero module+output stage+transformer
25. PeterKD: complete DAC (item 6)
26. rredline: Output stage only
27. schallundrauch: complete DAC (item 6)
28. Stenachio: Complete DAC without output stage (option 6 without option 2)
29. ervstil: DAC module + Amanero
30. linuxfan: output stage only
9. Mas Penk: DAC module + amanero + transformer + chassis
Editted a bit of.my order, i removed the output stage (already order LL1684 from other quanghao's thread)
I removed myself. Updated list:
21. Jazzbear: DAC module + output stage + transformer
22. frankwilker: DAC module + Amanero module + output stage
23. NKL: DAC module + Amanero module+output stage+transformer
24. PeterKD: complete DAC (item 6)
25. rredline: Output stage only
26. schallundrauch: complete DAC (item 6)
27. Stenachio: Complete DAC without output stage (option 6 without option 2)
28. ervstil: DAC module + Amanero
29. linuxfan: output stage only
I took the place created by CafeNoir's removal.
30. msaywitz:DAC module + amanero + output stage + transformer + chassis
Sorry but I'm going to need to remove myself
14. Removed
30. msaywitzAC module + amanero + output stage + transformer + chassis
As colesey has withdrawn from position 14, I have slipped the list up:
14. claudio52: Output stage only
15. Nick F: Complete DAC exclude output stage (item 6 - item 2)
16. xtomm: output stage only
17. brgds: DAC + output stage + amanero
18. danny_66: output stage only
19. anjogi: amanero + DAC + output stage + transformer
20. Jazzbear: DAC module + output stage + transformer
21. frankwilker: DAC module + Amanero module + output stage
22. NKL: DAC module + Amanero module+output stage+transformer
23. PeterKD: complete DAC (item 6)
24. rredline: Output stage only
25. schallundrauch: complete DAC (item 6)
26. Stenachio: Complete DAC without output stage (option 6 without option 2)
27. ervstil: DAC module + Amanero
28. linuxfan: output stage only
29. msaywitzAC module + amanero + output stage + transformer + chassis
Hi Quanghao,
I already own the first version of the DAC-END, it's great.
I am on the list for just the new output stage. Can you tell me what I need if I want to change to the LL1684 transformer output stage? Can I just buy the LL1684 transformer or do I need to make additional modifications?
Hi Quanghao,
You need to remove the output jump to convert in voltage mode and connect the LL1684, there is a pcb with connectors available from Quanghao
Updated list, since I'll just need the LL1684 output board.
Removed myself from this list and now position 6 is available.
6.
MattMax has withdrawn from position 6, list slipped up again:
6. CAAD: output stage only
7. Blackberry: output stage only
8. Mas Penk: DAC module + amanero + transformer + chassis
9. rade95: output stage + chassis
10. vmoreau: DAC Module
11. sandor: Complete DAC without output stage (option 6 without option 2)
12. Erlend Sæterdal: Output stage only
13. claudio52: Output stage only
14. Nick F: Complete DAC exclude output stage (item 6 - item 2)
15. xtomm: output stage only
16. brgds: DAC + output stage + amanero
17. danny_66: output stage only
18. anjogi: amanero + DAC + output stage + transformer
19. Jazzbear: DAC module + output stage + transformer
20. frankwilker: DAC module + Amanero module + output stage
21. NKL: DAC module + Amanero module+output stage+transformer
22. PeterKD: complete DAC (item 6)
23. rredline: Output stage only
24. schallundrauch: complete DAC (item 6)
25. Stenachio: Complete DAC without output stage (option 6 without option 2)
26. ervstil: DAC module + Amanero
27. linuxfan: output stage only
28. msaywitz: AC module + amanero + output stage + transformer + chassis
