Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 5th September 2018, 12:33 PM   #431
Jezza56 is offline Jezza56  Australia
Hi Ray,
Great news I have got sound...lol... although it isn't very loud but I hope there may be something we can do to increase output..... it turns out that the input + and - labels are wrong on the board so I was basically shorting out the board to ground through the input rca. Is there anything I can do to increase the output.
Jerry.
Old 5th September 2018, 04:28 PM   #432
rayma is offline rayma  United States
There isn't any way to significantly increase the gain of the tube circuit.
Is your step-up transformer x10 gain? What is your cartridge's nominal output?
Old 5th September 2018, 11:25 PM   #433
Hi Ray, my MC output is 0.5 mv and transformer is 10 times si
O I will have to get larger step up.
Old 5th September 2018, 11:28 PM   #434
That really should be enough gain. How about the gain in your line stage and power amp?
Old 5th September 2018, 11:57 PM   #435
I will try the phono on my Denon tonight as the yamaha amp is from the early 90s and let you know. I will double check the stepup output as i did buy it second hand and the original owner was not pleased with its performance.
Old 6th September 2018, 12:13 AM   #436
The step-up should have enough gain to allow normal volume with any associated equipment.
Old 7th September 2018, 03:43 PM   #437
Hi Ray, I purchased an oscilloscope today and although I don't understand a lot about them yet it did allow me to observe voltages a bit better. I don't have a test record so just used normal lps and it seems I am not getting any more than 2 to 3Mv out of the step up transformer. I have a project Phono box from which I set to MM and plugged output into my phono stage then into an amplifier and it works fine although there are 2 RIAA circuits in play instead of one as the project box has its own RIAA circuit also. To achieve normal volume the phono stage needs 4.5Mvs so I am thinking I will need a pair of Lundahl LL1941 although I still don't know why the MC1 does not provide enough gain as it specs suggest it to be 1:12.9. The MC1 spec states 47Kohms for input impedance where the phono is 50Kohms does this have any bearing on gain.
Old 7th September 2018, 06:32 PM   #438
You are measuring about right. There should be enough gain with the step-up and one phono stage.
All the specs are fine. Please don't start buying things, because you need to determine the problem.
Do you have a mm cartridge to try, or a different step-up?
Old 22nd September 2018, 12:14 PM   #439
Hi Ray I have added a moving magnet to my record player with .7 Mv output. There was a little improvement however still donot have enough gain to drive a normal amplifier input. I think now the only option is to build a line stage to get the signal gain after the phono stage. I spoke to Mark at Blueglow and he suggested that it may be the overall design and Bias I am still trying to learn as much as possible so hopefully I will grasp how to maybe adjust this when I learn more. Do you know what the actual gain of this design has been achieved by other builders or is it just a no brainer about incorporating a line stage preamp.
Jezza
OLD THREAD Hi-end phono preamplifier by Andrea CiuffoliHide this!Advertise here!
OLD THREAD DAC End by Andrea Ciuffoli quanghao Quanghao Audio Design 2063 21st March 2015 10:25 AM
Hi-end phono preamplifier quanghao Quanghao Audio Design 8 30th June 2010 04:37 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
