Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 3rd May 2010, 05:43 AM   #1561
cchean is offline cchean  United States
Originally Posted by quanghao View Post
You can write new group please!
Thank you!
1. kannan = full set
Quanghao,
I am new to this thread. I want to build the dac end dac, how many boards I need and how to order them?
Old 3rd May 2010, 05:51 AM   #1562
housing is offline housing  Hong Kong
Originally Posted by fredlock View Post
I also bought an R80-36 transformer fro Diyclub and its 230Vac secondary outputs 250Vac reading on my fluke meter, the 260Vac secondary outputs 283Vac. I don't know why it's reading too high.
I have bought the same transformer for the tube IV stage. That's normal due to regulation of the transformer. You will get the specified AC voltage if the transformer is fully loaded.
Old 3rd May 2010, 06:42 AM   #1563
fredlock is offline fredlock  United States
That's what I thought too, but I'm still getting 280Vac even with the load.
I finally fixed the problem with the LED not turning off when plug in to a CD. It was a cold solder on the CS8414 pins. I retouch the soldering and now I'm listening to music. Very cool! very nice Dac. I like the sound, as what everybody says. The only disadvantage is, it's HOT. My next plan is to incorporate a USB to SPDIF converter board so I can connect it to my laptop or desktop computer.
How about you Housing, is your Dac done?
Old 3rd May 2010, 06:58 AM   #1564
pathetic is offline pathetic  Australia
I'm gonna start a new list for a full set PCB:
- PCB- DAC END 2
- PCB- Salas Shunt For DAC
- PCB- I/V stage
- PCB- 10M45 for I/V
1. pathetic (1 set)
Old 3rd May 2010, 07:09 AM   #1565
flocchini is offline flocchini  United States
Yes! i test it, Some use TL 431 is not good, but after Salas shunt it is good!
I want try to make all Salas shunt for DAC-end 2. Now I'm testing it. if it is good i can reply!
PM: And I use Salas Shunt HV for IV, the sound is excellent,
One test with 6h30pI or 6h6, I show the sound is very very natural. sound more realistic and very detailed. I think it fits the sound quality of the AD 1865. I can say I love 6h30.
Best regard!
Thank you!
Quanghao:
Are you going to to a 6H6P board?
I will be interested in the Salas HV board to use with the E182CC/5687?
Bob
Quanghao
Old 3rd May 2010, 08:34 AM   #1566
quanghao is offline quanghao  Viet Nam
Send a message via Yahoo to quanghao OLD THREAD DAC End by Andrea Ciuffoli
Yes! you can see the circuit
The Best DAC is no DAC http://www.audiodesignguide.com/DSC2/index.html
ES9038PRO: http://quanghao.com/
Old 3rd May 2010, 03:57 PM   #1567
ksnider1 is offline ksnider1  United States
Default I/V stage relay
Does anyone have mouser part for I/V stage relay ?
Old 3rd May 2010, 04:14 PM   #1568
Mouser Part #: 769-DS2Y-S-DC5V
Manufacturer Part #: DS2Y-S-DC5V
Old 3rd May 2010, 04:36 PM   #1569
- PCB- DAC END 2
- PCB- I/V stage
1. pathetic (1 set)
1. pathetic (1 set)
2. cchean (2 sets)
Old 3rd May 2010, 05:15 PM   #1570
Thanks housing
OLD THREAD DAC End by Andrea CiuffoliHide this!Advertise here!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 438 22nd September 2018 12:14 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
