Aging solder joins of power transistors
I observed degrading solder joins of the power transistors of my Accuphase amp. The Amp is thirty years old. When I re-soldered them, they even crackled. Has anybody experienced this phenomenon? I think it's due to mechanical stress between the heat sink and the PCB. It could be caused by warming and cooling of the transistor. What do you thing? Stephan |
funny you mention that just now. I noticed the same thing on an old amp I'm redoing. Not really sure what's up with that. It stinks too,..might being the wiring insulation though.
Some of the old solder I used in the late 60's did have a funny smell and I too have noticed it when repairing old stuff.
I put it down to the type of flux used rather that old wiring. I think the problem, which i too have seen in some old Armstrong amps, is due to thermal stress. A similar phenomenon is found in old computers or any old equipment with socketed chips. In old IBM PCs, the memory chips would get so loose they would fall out !!!! Andy |
there are hundreds of solder flux "recipes" used around the world.... some are pretty bad, smelling like cat urine in some cases...... especially bad are the water soluble fluxes..... kester fluxes aren't bad, most of them smell like pine. i suppose also, like vegetable oils do, that some fluxes could become rancid after a long time. organic chemistry isn't my strong suit, but a lot of organic oils and resins slowly oxidize over time, usually making them smell very bad.
yes, the thermal cycling of transistors causes stress failures in solder connections. you will notice most of the time, it's the collector leads that have stress rings in their solder joints, since it's the collector lead that's got a direct thermal connection to the transistor die, and expands/contracts the most. |
The worst melling flux is that crap in old valve gear...
Quote:
Remelting the solder with a tiny smear of paste or liquid flux over the joint should renew the connection and take out ALL the fatigue stress/strain. |
Re: Aging solder joins of power transistors
Quote:
subsequents cracks when equipment go in thermal cycle for years. Usually this defect come up after some or many, when warranty is abundantly gone for good... Hi Piercarlo |
Quote:
Stephan |
Quote:
I may be wrong but from my experience I tink they have trouble to set wave or automated soldering process for all types of component at same time if they set process for light pins or wire it will not work on heavy component ( many times I saw connectors pins or relay with poor solders and cracks ).
I think they have not be heated to correct temperature in automated process, this is why they dont last. If they set process for heavy component it may be too hot for light components, this is why you may have trouble with heavy components when they are soldered on automated machines. |
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by
vB Optimise (Pro) -
Copyright ©1999-2021 diyAudio
