digital experiment
Hi
A few weeks ago i start an experiment. I rip a cd with excellent recordings, I resample the file at 176.4 KHz with Wavelab and after that I burn the result on a DVD with Diskwelder crome, the result a DVD audio with 16bit 176.4 kHz LPCM information. I play the result on a budget DVD Player like Panasonic S52 an the result was fabulous. A beautiful sound on budget equipment. The sound was different more clearly, the instruments more distinctly, more natural. The system that i have at home and listen the experiments Amp Onkyo A 8870, DVD player Panasonic S52, CD Player Sony CDP 515, Speakers JBL ATX 60, interconnect Ixos and speaker cable Ralcable Bimetal 4mm. Question. Is this a good way to listen music on budget equipment? These procedures make the same thing that expansive cd players do? The result is near to a good cd player? I want to do something else now. I want to find a decent DAC and try to listen again the result of the experiment. If some one tries the same experiment and have some good result or knowledge to share, please type on this post. Have a nice weekend |
Well, it is a good enough way to "uncompress" the over all headroom of the compressed CD files ... 44k uncompressed to 176k ... basically "undoing" the work of the publishers' mix down engineer to some extent.
Your results will of course be determined by the level of quality of the original ... sometimes the results will be very nice indeed, sometimes not ... I would speculate that vocals and acoustic instruments would show improvements, overly compressed electrified (and possibly distorted) instruments = not. Try it on an album of acoustic music that is obviously degraded by the mix down process ... example: Eric Clapton's "Me and Mr. Johnson" is overly compressed acoustic guitar and vocals to the point of (possibly deliberate) introduction of distorted and clipped information === maybe this CD is beyond help ... maybe not. :apathic: " a decent DAC " ... IMOP would be a DAC capable of multi-channel 24bit / 192k (or 96k x 4 channels) ... something not normally found in USB connected devices, but there are some that can do it. A bi-directional (record & playback) device like this would do it ... http://www.m-audio.com/products/en_u...Solo-main.html ... or this: http://www.m-audio.com/products/en_u...kPro-main.html ... or this: http://rolandus.com/products/product...1&ParentId=114 ... the idea here is to rip and play 24 bit audio capable of putting the DVD-Audio and DVD player scenario to its full potential. :bigeyes: |
What you actually do is to substitute the oversampling filter integrated in the D/A converter chip itself with a much better one processed offline on a computer. No wonder it sounds much better. Cheap players use cheap DACs with horrible digital filters, expensive players use, well, the best DACs market has to offer with mediocre digital filters. More info here.
You have introduces a lot of jitter by ripping, upsampling, burning the DVD, and playing "the original information" back on a cheap DVD Player - and you liked the sound: rounded, layed-back, "more analog-like".
A bit of jitter here and there (at correct spectrum) can do “wonders”... Boky |
Quote:
you are right though that the spectrum of the jitter is very important to the percieved sound, jitter amplitude in time domain doesn't tell much about it.. |
Quote:
First, I really really wonder how it comes that ripping a CD to wav introduces jitter. If i had a 650 MB textfile on a CD and copied that textfile onto my hard drive I expect all letters in that textfile to be 100% correct on the HD. Why is this different when ripping a Audio CD? In my knowledge there shouldn't be any jitter introduced in this procedure. Then I wonder how upsampling would introduce jitter, what it actually does is what Glassman sugests, the jobb that the oversampler actually has. However since this isn't done in realtime the quality can be greatly improved. As far as I understand, this is a great way to improve the experience of listening to your favourite CDs. |
Hi folks.
Jitter effects on audio quality is a realtime issue only. If you run a non realtime bit perfect application, such as ripping to file, or transfering files, you won't have any issues, unless your Laser can't read a bit properly. But that's not jitter. Ripping to file doesn't introduce jitter. Writing to CD introduces jitter though. The pits are written to CD with a certain Jitter by getting different distances to each other. This of course causes jitter immediatly by the time the data are read-out, converted and played in realtime from CD. This is one of the reasons why the data should stay IMO on the harddisc. If that is no option, there are just a few CDROMs out there, such as Plextor Premium 2, which introduce very low jitter when writing CDs. Many people report good results with these drives. With gold CDs and a premium drive you have a good chance to end up with better sound as before, since the pits are much better written to the gold surface then on the original. This is causing less jitter when reading-out again it realtime. I would not call jitter an analog issue as pointed out by glassmann. The digital data are getting inhomogenous before they become converted to analog. It is a purely digital cause for jitter. Analog jitter what's that supposed to be! Jitter is getting appearant though, by the time the jittery stream is realtime converted to analog! You can also increase the jitter in the stream by doing upsampling here and downsampling there, poor clocking, poor and noisy power supply of the crystal, converting from USB to SPDIF - you name it. I do offline upsampling from 44,1 to 48khz with "Voxengo R8brain Pro" by myself. The offline conversion is giving me great improvements, even when compared to Shibatch realtime SRC. Shibatch is most probably a great algorithm introducing no phaseshifts whatsoever. But doing it realtime will have certain effects on the jitter induced to the stream. Cheers |
Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
again, you don't introduce any jitter via digital signal processing, only if the interference generated inside the computer would change dramatically under load caused by realtime processing, which to me is not quite probable.. |
Jitter has no effect when you are just in the digital domain.
1+1 = 2 2+2 = 4 3+3 = 6 It doesn't matter if you do those sums exactly 1 micro-second apart, 1 second apart, 1 year apart, or do 1 then get bored and go away for half an hour for a cup of tea and then come back to do the last 2. The answers will always come out exactly the same. So long as the data is in the right order and bit correct the actual timing has no effect on the results. Also something to note about pit/land jitter, remember the data on a CD is not stored in linear order. The data is interleaved. |
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by
vB Optimise (Pro) -
Copyright ©1999-2021 diyAudio
