diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Chip Amps (https://www.diyaudio.com/forums/chip-amps/)
-   -   high voltage on speaker terminal (https://www.diyaudio.com/forums/chip-amps/91477-voltage-speaker-terminal.html)
marcus7601 2nd December 2006 08:58 PM
Can someone help me with my first gainclone? I am using LM3875-kit from Audiosector. On right channel speaker terminal everything is fine. On left however i have -38V !! this is from my 25V transformer after rectification. How can this be?
I dont use a chassi so speaker ground goes to OG on pcb?
Nuuk 2nd December 2006 09:51 PM
Make sure that you have both power rails (positive and negative) connected properly.
If you can, measure the voltage on the pins of the chip but be very careful that you don't cause a short! ;)
It is more than likely that one rail is not connected! :att'n:
marcus7601 3rd December 2006 10:12 AM
ok, i will recheck my solderings.
marcus7601 5th December 2006 06:33 PM
Ok, i have resoldered +V and -V on the rectifier and amp-pcb still same results. I need some help here...
jan.didden 5th December 2006 06:38 PM
Quote:
Is the voltage on the chip output pin the same as on the speaker terminal? What is the voltage on each chip power supply pin? Measured?
Jan Didden
marcus7601 5th December 2006 07:02 PM
No on output i have 0V
On -V powerpin on chip i have the same as on terminal -35V
Edit:
I get -35V on output pin
Nico Ras 6th December 2006 06:54 PM
Hi, I had a quick look at the data sheet from National. On the faulty amplifier can you measure the voltage between ground and pin 7 as well as the voltage betwen ground and pin 8 of the LM3875.
We will establish if this is input related.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
