diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Chip Amps (https://www.diyaudio.com/forums/chip-amps/)
-   -   supply rail voltage on 3875 output ? (https://www.diyaudio.com/forums/chip-amps/89707-supply-rail-voltage-3875-output.html)
Buhl 5th November 2006 11:35 AM
Hello
Having assembled my god knows what number gainclone, I find it to behave strange - that is I have 25 volts on the output og leg no.3 - I have double, triple and quadruple checked everything.
Both channels behave this way.
Any suggestions ?- blown chips ? anything ?
Cheers !
Buhl - who's getting more grey hair than I should.....
Leolabs 5th November 2006 12:08 PM
Single supply or dual supply???
Nuuk 5th November 2006 07:49 PM
Buhl, I have also got quite a few successfully completed GC's under my belt but I started making a paralelled LM3875 and found that I had 25 volts on the output (37 volt rails). I separated both sections and found that they also both have 25 votls on the output.
I have been over this amp I don't know how many times and cannot find anything wrong so I too would welcome any suggestions! :xeye:
Buhl 5th November 2006 07:50 PM
Dual supply, 18-0-18 vac supply, 25 volts rectrified - one rec. bridge / channel - 25volt caps (mabye cutting it close, but they are good so i would like to use them.
Cheers !
Buhl
Nuuk 5th November 2006 07:51 PM
So you are getting the full voltage on the output and I am getting 25 volts from 37 volt rails! Even more mysterious! ;)
Buhl 5th November 2006 08:08 PM
exactly - 25 volts in and 25 volts out - nice equation.....
Nordic 5th November 2006 08:46 PM
Which at least in theory = a dead short... oh well glad to see I'm not the only one in chipamp hell this weekend. At the rate I'm loosing hair graying is not going to be a big problem...
Shigeko 5th November 2006 10:06 PM
I've heard you can have that problem if you dont have a 47k Resistor to ground behind your dc filter Capacitor at the input. And I had the problem because the negative Input was connected to the wrong side of the 20k negative feedback Resistor...
Buhl 7th November 2006 10:39 AM
Yehaa !
Thanx for helping me turn the magnifying glass in the rigth direction - I had looked only at the amp board again and again, and found no errors, turns out I had forgot to attact signal ground to star ground with a lead from the volume pot, hence no resistor from signal input to ground....works like a charm now !
By the way, the Elna Cerafine caps i use in the PSU(1000uF/25V) is a lot better than the "standard" panasonic FC caps to my ears - with the pana caps the highs got a little sharp og edgy, now they are detailed and not straining to listen to - well worth their relativly low price I think.
Thank you!
Cheers !
Hans
CarlosT 7th November 2006 04:14 PM
When everyone talk about DC rail voltage, is that measured between the V+ and PGN+ and not V+ and V-?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
