hifive said:I've changed my Naim CD5 OPA 604 to OPA 627 and the improvements was good. But the only issue is in the vocal "ssss" too sharp. How should I rectify that...
You can try decoupling from V+ to V- with npo 0.1 u ceramic and or decoupling to 0 rail. I personally don't like the dry character of the 627 and prefer class A bias on AD825 or heavilly dceoupled LM6171.
You should not always believe what you read about the 627
Re: Re: OPA604 to OPA627..some problems
With you there, the AD825 has killer transients and powerful tight bass, yet remains smooth as silk because it runs stinking hot in a lot of Class A, wish they made small SMD heatsinks for these. they really need them.
Cheers George
Cheers George
Re: Re: Re: OPA604 to OPA627..some problems
How did you bias the AD825 to class A ??
For heatsinks, use u-shaped alloy channel available from hardware shops epoxyed to the chip. It overlaps a little but you can still solder. Brass channel is also available from model shops.
Andy
Cheers George
Andy
Re: Re: Re: Re: OPA604 to OPA627..some problems
Running at -15 +15 they run quite hot to the touch, (and no, they're not oscillating) to the point of wanting to cool them with a heat sink. OPA134,OPA2134 & OPA4134's SMD's, run this hot and also sound great, but the AD825's have better slam.
Cheers George
Andy
Cheers George
Cooler Master have a small self adhesive heatsink that fits well on DIP-8 opamp.
http://www.coolermaster.com/index.p...-P01&other_title=SAC-P01Little Chipset Cooler
banana said:Cooler Master have a small self adhesive heatsink that fits well on DIP-8 opamp.
Yeah, but wot's needed is one for SMD size chips, 2 banger and 4 banger.
Cheers George
hifive said:
I'm getting 637BP next week!
Be careful !!!
Read the application notes !!!
Not unity gain stable !!
Andy
- Digital Source
- OPA604 to OPA627..some problems
