diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Multi-Way (https://www.diyaudio.com/forums/multi-way/)
-   -   Vent length question (https://www.diyaudio.com/forums/multi-way/86766-vent-length-question.html)
DAMIC 19th September 2006 10:37 AM
I am just curious, maybe someone already asked the question, but I don't know how to search (key word).
Considering bass reflex type of enclosure, dezired tuning frequency, beside all factors is dependent by the length of the vent. For example, volume of the box is 0,9 ft3 (about 25 l) vent tube is on the outside cut as usually, under angle of 90 degrees but inside the box, the other end is cut under angle. So, looking from the side the trapezoid shape is obtained. Diameter of the tube is 2 inch, upper tube length is 2.3 inch what corresponds to dezired tuning frequency of 50 Hz and other longer length is 4.42 inch corresponding to tuning frequency of 40 Hz.
Well, I am wondering, what should be the final tuning frequency of the enclosure, 40Hz, 50Hz, something in the middle, or should maybe the tuning frequency be wider than usually (spread between 40 and 50Hz).
Thank's in advance.
soongsc 19th September 2006 10:46 AM
It really depends on what driver you are using and what its resonant frequency is.
Tyimo 19th September 2006 12:53 PM
Hi!
You have to calculate the tube's air volume and than you can model and calculate a "normal" vent tube with the same volume of air you found.
Another way: just calculate with the avarage tube lenght. :)
Greets:
Tyimo
sreten 19th September 2006 01:00 PM
The tube will operate as though it is slightly longer than
the shortest length, its not a good shape for good airflow.
:)/sreten.
DAMIC 20th September 2006 06:53 AM
Thank you very much for your replies.
Kind regards,
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
