diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (https://www.diyaudio.com/forums/tubes-valves/)
-   -   Best way of reducing heater voltage? (https://www.diyaudio.com/forums/tubes-valves/83406-reducing-heater-voltage.html)
showdown 19th July 2006 11:07 AM
I've just finished breadboarding Mikael Abdellah's KT88 amp, and everything seems to be working just fine (on the 1st try, woo-hoo!) except for my heater voltage, which is a little bit high. I've measured between 6.5 and 6.6V, depending on line voltage.
What is the best way of lowering it? Just a big fat power resistor, or are there any other, less-brute-force approaches?
thanks,
Rolf
ErikdeBest 19th July 2006 11:19 AM
I think the 'big resistor' approach is good! If you are using DC try to break the resistor in smaller ones, and decouple each section: provides for a nicely filtered DC voltage.
If you are using a toroidal you can try to take one turn of the filament secondary.
Sherman 19th July 2006 12:40 PM
Congratulations! I have built this amp (I built mine as monoblocks) and believe you will love it.
The power resistor method is definitely the easiest. With the KT88s drawing 1.6A and the 6N1P pulling 0.6A just make sure it is big enough!
As Eric said you could convert the heaters to DC and use a couple of smaller resistors and some caps to filter the current. However with this design DC heaters aren't at all necessary to have a hum-free amp.
danFrank 19th July 2006 03:53 PM
Tube heaters can take a 10% variance in either direction' so 6.6v is OK. Why bother? And don't tell me about tube life!
If the heater winding is CT to ground then get TWO equal valued resistors (figure out the voltage drop needed for the value) and put one on EACH of the 6.3v windings. This will be best for reducing hum. If one side of the winding is grounded then only one resistor is needed.
Daniel
Merlinb 19th July 2006 06:55 PM
Quote:
Originally posted by danFrank
If the heater winding is CT to ground then get TWO equal valued resistors (figure out the voltage drop needed for the value) and put one on EACH of the 6.3v windings. Daniel
Or use one resistor and place it between ground and the centre tap.
rdf 19th July 2006 08:06 PM
Another option if you want a little RF filtering is a pair of hash chokes terminated with a good film cap. Many chokes intended for this current have a less than 0.5 ohm internal resistance. Pick a pair that gives the proper drop. Make sure to oversize to avoid buzz.
Tubelab_com 19th July 2006 08:15 PM
There should be no current flowing in the center tap, so a resistor here wouldn't do anything. The center tap is used to create a balanced transmission system (similar to the electric power in the US) so that hum radiation from the filament leads will be equal and out of phase, cancelling out.
This is why you would use two equal resistors to keep things balanced.
jane 19th July 2006 08:33 PM
What about reducing the heater wire size?
You don't need many extra milliohms to drop 0.2-0.3V.
agent.5 19th July 2006 09:21 PM
Add a common mode choke in the primary.
showdown 19th July 2006 11:57 PM
Thanks for the replies, everyone!
I'm using AC heaters for now, since a 3.8A DC arrangement would be a little more complicated. The winding is center-tapped/grounded through 2x 220R.
I'll try a resistor on each side of the winding, I just hope I have the right parts around here.
Quote:
In the primary? Would something from a switched PSU work? I have a couple in the bin, measuring 0.3 ohms each side.
It won't matter if the HT is lowered, it's already 430V (vs. 400V in the schematic).
thanks,
Rolf
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
