diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Solid State (https://www.diyaudio.com/forums/solid-state/)
-   -   Scalable Power Supply GB (https://www.diyaudio.com/forums/solid-state/77039-scalable-power-supply-gb.html)
BobEllis 3rd April 2006 06:11 PM
Just in case you missed it, I am running a group buy for a scalable power supply. The board includes rectification, filtering and a regulator that is suitable for a broad range of voltages, depending on component selection. Positive and negative sections are completely independent. Board price is $5.
A parts kit is being offered for +/-15V @ 1A nominal operation. The parts kit includes LM4040-10 voltage reference. You can use a standard zener or LM329 as well. Parts price is $20.25
Voltages from 10 to 50V are possible with resistor changes. Lower voltages will require a different voltage reference. Operation at >50V is possible by using suitable semiconductors and changing the voltage reference current setting resistors.
Also offered is an Avel Y23 series toroidal transformer with dual 115V primaries, dual 0-18V (may be 0-15V depending on test results) and mounting hardware. Price is $16,50 or less, depending on quantity.
See Wiki Page for information
This supply was developed to power active crossover boards. These boards are available HERE
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
