diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Lighting and OHP (https://www.diyaudio.com/forums/lighting-and-ohp/)
-   -   DIY GBA Backlight. GBA = Game Boy Advance. A project I'm Working on. Any ideals? (https://www.diyaudio.com/forums/lighting-and-ohp/74729-diy-gba-backlight-gba-game-boy-advance-project-im-ideals.html)
Gamerjoe 25th February 2006 12:16 PM
Hello members here. I brought a GBA and like most who brought the old model it dose not have an internal light source. I have heard of some mod that you can get called an Afterburner Kit which is an internal light kit.
The Afterburner Kit though is discontinued and most sites online are out of stock. Some want crazy prices for it also. I even heard bad news about kit making screen bleed or problems with getting air bubbles on the LCD. Also the light dosen't spread evenly!
I was wondering is there a way to make your own internal kit some way? I've researched the internet and found some ideals but would like your help. First I need to know what kind of clear material that spreads ligt evenly? Could it be a EL sheet???
The GBA has a Reflective TFT screen so the light source has to be spreaded around the LCD or above it to reflect light. Though I need a light source small enough to put inside a GBA.
What I really want to know is how can I make my own kit and waht would work best?
superdaveumo 25th February 2006 08:28 PM
You could try putting a small array of LEDs behind it. They'd have to be small LEDs and you might have to modify the casing.
hailrazer 25th February 2006 09:18 PM
It's near impossible, I did a LOT of research into it when the Afterburner kit was being made.
The plastic is a "light guide" . It's a piece of plastic with angled grooves cut into it. Then the light shines into the side of it and the grooves refract the light down onto the Lcd.
The grooves have to be cut at the precise angle depending on the amount of light being used and the size of the plastic.
And the companies that make the light guide require a minimum order of around 10,000 and a deposit just to do the research necessary to make the prototype.
hailrazer 25th February 2006 09:19 PM
Quote:
Won't work , it usues a reflective TFT Lcd. Light won't shine through it.
Gamerjoe 25th February 2006 10:17 PM
How about some form of light that gose around the LCD? Could that be possible? Like a framed light round LCD for example putting light behind a Flat Sceen to give it that extra glow? Also thanks for the relies! I am still looking into ideals. Thanks again!
antony0619 6th September 2013 08:27 PM
Hello Game boys.
ZLONE - Small Orders Online Store, Hot Selling SP LCD DIY,GBP LCD Screen,GBC LCD and more on Aliexpress.com
game boy DIY LED front light ,I got some pcs and changed the back light of my game boy
There are also some videos show how to do it. Hope it is helpful to you.
Antony
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
