diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Class D (https://www.diyaudio.com/forums/class-d/)
-   -   Toroidal transformers (https://www.diyaudio.com/forums/class-d/52200-toroidal-transformers.html)
muddy 23rd February 2005 08:47 PM
Hey Folks,
Im trying to Design a Car Amplifier, but I have ran into a problem with the power supply circuit. Seems that finding high Watt transformers which will handle a 20khz signal. in relatively small packages is impossible other than turning my own(dont want to do). Please help, or guide to another design concept. Anyone done a tranformerless high power supply for audio application?
Muddy
subwo1 24th February 2005 08:23 PM
I did a project for a medium power one for a car amplifier by using a charge pump once.
hypnopete 25th February 2005 12:02 AM
Hi Muddy,
I also have built a switchmode power supply for a car amplifier before. It was 400W at 12V, I wount the toroidal transformer myself.
Its supprisingly easy especially if you use a nice large toroid. I think winding one is your best bet, unless you want to pay someone else to wind it for you, however that will get expensive.
Peter
dmfraser 25th February 2005 12:23 AM
Transformer
In one of the articles in the Class-D section of the audio\circuits section of www.schematicsforfree.mattsoft.net there are instructions of how to wind a transformer.
Of do what others have done. Go to an amp repair shop and buy a blown up amo they junked. You will get all the hard to find bits you need out of it. After al, the transformers seldom go when the amps die. Just as long as the one you get does not have the transformer burned up, you're fine.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
