diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Parts (https://www.diyaudio.com/forums/parts/)
-   -   Age-old Power MOSFETS again... (https://www.diyaudio.com/forums/parts/50723-age-power-mosfets.html)
Emmy 1st February 2005 05:53 PM
Hey all,
This is my first post here, so hi all! My first question is to do with Power MOSFETS again... I know this may have been answered before, but I can't find it in the search engine! Basically, my question relates to the difference between the 2SK1058 and the BUZ900DP... Since the BUZ900DP is a double-die version of the 2SK1058, would it be okay to replace two parallel 2SK1058's with one BUZ900DP (and two parallel 2SJ162's with one BUZ905DP)?
The only major difference I see is that the power handling of the BUZ devices is only 250W, compared to 300W of the combined 2SK1058/2SJ162 pairs.
If the consensus seems to be that the BUZ devices can easily replace two of the 2SK/2SJ devices, I was going to try it in Randy's Opti-MOS design. I assume that to be "safe", I should only run the system at 200WRMS into 4ohm?
Any comments appreciated!
Thanks!
Shash.
richie00boy 1st February 2005 06:18 PM
You can do it fine and you have recognised the power differences as well.
I prefer to use separate device though because it's easier to make thick tracks from the devices than monster tracks. Also, the surface area to the heatsink is a little more with separate devices. This is one of the reasons why power handling is a little lower.
Emmy 2nd February 2005 12:06 PM
Thanks for the reply! The only reasons I'm looking at reducing the number of output devices are cost and size. The project I'm working on needs to be as compact as possible, and I can get these BUZ devices for only 1 more than the 2S's!
Thanks!
Shash
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
