diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Solid State (https://www.diyaudio.com/forums/solid-state/)
-   -   how to make a clean square wave? (https://www.diyaudio.com/forums/solid-state/40101-clean-square-wave.html)
sss 28th August 2004 08:27 AM
i wonder how to make a square wave with no overshoots like the frequency generator .
plus
what type of input buffer/op amp used in scopes that can show a clean square wave (or any other)?
Pabo 28th August 2004 05:37 PM
Build an oscillator with a schmittrigger inverter, a resistor and a capacitor. Set the frequency by altering the resistance. Put a flip-flop after for generating 50% duty cycle.
sss 28th August 2004 05:54 PM
will that be as good as the freq generator?
i got many op amps and when the input signal is a square wave theres always an overshoot , i guess thats because they are too slow right?
:rolleyes:
what type of amps/buffers used in scopes that shows the wave as it is?
sajti 28th August 2004 06:08 PM
Audio amplifiers/buffers are not the best solution for square wave amplification. So for this, use non feedback swithcing type output stage. Use low impedance and high current..
sajti
sss 28th August 2004 06:12 PM
does feedback causes the overshoots?
sajti 28th August 2004 06:18 PM
Quote:
Yes. I had a schematic for one HP scope. It contains 10kHz squarewave generator. In this generator there was no any feedback, and it produced extremly perfect squarewave
sajti
sss 28th August 2004 06:25 PM
so what kind of amp do they use at scopes input?
it should amplify / attenuate all types of signals
pinkmouse 28th August 2004 06:38 PM
Have you seen the MAX038? It is a very good chip that needs few external components to give a frequency generator, with nice even square waves.
OliverD 28th August 2004 06:48 PM
The trick is bandwidth.
Remember a perfect square wave of frequency f is a sum of several sine waves: 1 x f + 1/3 x 3f + 1/5 x 5f + 1/7 x 7f.... up to infinity. To correctly amplify a mixture of sinewaves with frequency up to infinity, you need of course an infinite bandwidth.
There's nothing special about the input amplifier of a scope, except that it is a very sophisticated and very fast one.
In your case, where you limit yourself to squarewaves only, you could use a fast comparator at the final stage to square things up.
sss 28th August 2004 07:01 PM
Quote:
yeah but those fast amplifiers also can amplify "slow" signals with no distortion - thats special
:D
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
