diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Everything Else (https://www.diyaudio.com/forums/everything-else/)
-   -   Buzz or Noise in Distribution Amp Output (https://www.diyaudio.com/forums/everything-else/376780-buzz-noise-distribution-amp-output.html)
answerseeker 8th September 2021 02:50 PM
I have a multi-zone audio distribution system. Each output is 25w/ch and can support 8 or 4 ohm loads. In some rooms, I hear a hum or buzz when the system is off. In some cases, briefly turning the zone on will alleviate the matter temporarily. Doing so often results in a small audible "pop" as if it were relieving pressure at the output. In some areas, this action does not change anything.
I do not have info on the type of amp used. Sources and amps are all on the same power circuit. In my mind, this eliminates a ground loop scenario and points to a cheap noisy amp.
At present, every zone is an 8ohm stereo pair.
Is there something that can be done to bleed off this noise at the amp? Possibly a small resistor across the speaker outputs? Any suggestions?
JMFahey 8th September 2021 03:17 PM
I suspect some speaker wires travel near Mains one, maybe even thrugh same or side by side conduit.
In that case induced/magnetically coupled Mains voltage will reach speakers, weak but audible in a silent room.
Turning amp ON places a virtual short across wires.
Simple turn-on Pop, donīt look any further
Quote:
cheap noisy amp
Cheap amps are not noisy if OFF.
Nothing to "bleed" but you can kep amp ON.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 16.67%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
