diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Everything Else (https://www.diyaudio.com/forums/everything-else/)
-   -   Those pesky Abbreviations! (https://www.diyaudio.com/forums/everything-else/376400-pesky-abbreviations.html)
myleftear 29th August 2021 12:51 PM
Hello good afternoon my friends!
Just stumbled once more over Mr. Ohm.
I find it hard to remember that, for example, the ampere (A) is referred to as I.
Hell, why is that? Just so or is there a sort of a etymology to the denotations?
nigelwright7557 29th August 2021 02:13 PM
P power and W Watts is another one.
Cal Weldon 29th August 2021 02:27 PM
I is French for intensity of current. It was used by Mr. Ampere himself.
haiqu 29th August 2021 02:29 PM
Sacré bleu!
jean-paul 29th August 2021 02:37 PM
The incredible André-Marie Ampère indeed used "intensité" or I. He died in 1836 and he developed a theory that magnetism is caused by small currents that occur within the magnetic material. This was proven 60 years after his death.
The U for voltage is another story :) As all stuff was started in Europa things became named often in the language of the founder which could be any European country. The unit name often being derived from the name of the founder. The inventors of that time were contrary to those who achieve things in modern society exclusively male.
myleftear 29th August 2021 03:51 PM
So I may introduce an new unit for an old energetic phenomenon (in new socks): unit „D“ (like david) for varying levels of ignorance. :D
Mille millions de mille sabords!
(Ok, this was in 18th/19th century, but weren’t there any women in the club (or were they just ignored)? Later on we had marie curie among others…)
jean-paul 29th August 2021 04:00 PM
D = 1/(IQ x W). Ignorance =
1/(intelligence x effort)
I just mentioned it as it were almost all white males. The same sort that is seen as the cause for all bad things today in the woke culture. So anyone using their inventions maybe practices “appropriation” if I follow the intense ignorance and stupidity of the woke culture.
rif 29th August 2021 04:11 PM
!n argument can be made that Centigrade is far more useful than Celsius.
But you are correct, units get named after discoverers; Bells, Faraday, Tesla, Coulumb, mho, Gauss, Kelvin, Newton, Hertz, Volta, Amp....
jean-paul 29th August 2021 04:12 PM
Where mho is Ohm in reverse to indicate what the rest of the world calls Siemens. "mho" is according the SI an "unaccepted special name for an SI unit".
BTW Georg Ohm was ignored by the physicists in his home country even after his theory was accepted in the US. It took another 20 years to get acceptance.
rif 29th August 2021 04:19 PM
Quote:
Originally Posted by jean-paul (https://www.diyaudio.com/forums/everything-else/376400-pesky-abbreviations-post6769406.html#post6769406)
It's on my likeable list since the unit of measure tells you something about the physical property, as long as you understand Ohms
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 16.67%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
