diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Full Range (https://www.diyaudio.com/forums/full-range/)
-   -   Port length for microTower (https://www.diyaudio.com/forums/full-range/373815-port-length-microtower.html)
DoktaDave 22nd June 2021 09:19 AM
Hi
I'm almost certain this is a dumb question, but I can't work out what I'm doing wrong. I'm currently building a pair of the Microtowers from the frugal-phile website using the Pluvia 7HD. The port for this is specified as 3 inches diameter by 4 inches length. The pipe I have for this is 80mm internal diameter. It seems unlikely that that would make much of a difference, but to check, I've tried to re-calculate the port-length using the equation Lv=(23562.5*Dv^2*Np/(Fb^2*Vb))-(k*Dv) (as recommended in the plans). When I do it though, it tells me the port should be over a metre long. Where am I going wrong?
bansuri 22nd June 2021 10:18 AM
I think that guy mixed up inches with centimetres.
Scottmoose 22nd June 2021 11:00 AM
For an 80mm duct diameter, increase length to 108mm assuming a regular untapered type.
GM 22nd June 2021 05:11 PM
FYI/FWIW: Scaling vents: FE126E enclosure question
DoktaDave 22nd June 2021 06:28 PM
Thank you. This is exactly what I needed :)
GM 23rd June 2021 03:53 AM
:up: :D
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 16.67%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
