FS: Few different items - C relays, Meters, Caps, Cam, Cable
Up for sale few different items, selling of which separately has no big sense considering single way to accept payment and price of each item/shipping, but which can be combined to each other to increase sense of deal, or with adding to other our more expensive items how :
So, items :
1. Meters
Meters Marion, 2 inch, hermetized, glass soldered to body (but can be desolded with skill).
2pcs - 100mA, 500mA - red overlay - 20,-eur
2pcs - 30 microamperes, 50 microamperes - black overlay - 20,-eur
Meters - Google Drive
2. Mintron 1/3 CCD cam, chip board.
Model: Mintron MTV-53KS80AHP, PAL version
Sensor: 1/3 CCD
CCD total pixels : 798х584
Min illumination : 0.8LUX/F1.2/5600K
Resolution : 470TVL, 580TVL enhanced
WB range 3200-10K
S/N ratio : 52dBmin/60dB typ
Electronic shutter : AES 1/60-1/120,000sec, FIX 1/60-1/10000
Operation temp : -20C +50C
Power Supply : 12VDC 150mA
Board size 42x42, tallnes 40 with optic
Also possible additional optics.
https://drive.google.com/drive/folders/1SsurzsJuXb8Vtmmz9wOS9nuiXolO_OnU?usp=sharinghttp://
2 pcs on stock, 40,-eur each cam
3. Elelctrolytical caps 80-100uf, 400uf, 500uf & 50-450VDC, mostly for tube devices.
General Electric caps, Mallory, Planet Lyticap, Sprague, Cornel Dubilier, AeroVox.
Set 1 - 8pcs - 25,-eur
Set 2 - 9pcs- 20,-eur SOLD XXX
Set 3 - 14pcs - 20,-eur SOLD XXX
See more detail pics and specs in archive >> :
https://drive.google.com/drive/folders/1upKhx2wZvHdH9QbqPIgjw1X_8yfh-sYk?usp=sharing
4. High voltage mica caps, USA vintage, 1-5kV, AeroVox, Sprague, Sangamo, Cornel Dubilier
https://drive.google.com/drive/folders/1R5QWZqao1L086c-G1JgnnYNoVNKvjgo5?usp=sharing
21pcs - 15,-eur
So, items :
1. Meters
Sensor: 1/3 CCD
WB range 3200-10K
21pcs - 15,-eur
Added item.
9. Line level input step-down transformers Jensen JE-6110K-B, 4:1, up to +26dBu@20Hz.
Perfect for your comps, pres.
https://www.jensen-transformers.com/wp-content/uploads/2014/08/jt-6110k-b.pdf
2 pcs - 129,-eur
2 pcs - 129,-eur
10. Marion MM2 meters, 2 inch
200mA
10V
29,-eur pair
11. Raytheon, 3 inch
10,-eur 1pc only
12. Triplet 426 VU meter, 4.5 inch
19,-eur 1pc only
200mA
10V
29,-eur pair
10,-eur 1pc only
19,-eur 1pc only
