diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Analog Line Level (https://www.diyaudio.com/forums/analog-line-level/)
-   -   Parallel Primary Inputs of Two Different Signal Transformers (https://www.diyaudio.com/forums/analog-line-level/370604-parallel-primary-inputs-signal-transformers.html)
lukegalea16 8th April 2021 06:39 AM
I want to 'split' a balanced line signal so I was thinking of doing the following.
Balanced Line Output > 2 x 10k:10k Transformers > Separate Outputs
The balanced line output would be common for the primary inputs of the two transformers.
  1. Do you forsee any issues with this configuration?
  2. Will the input impedance of my system become 5kOhm? If so, what will be the output impedance now?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
