diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Solid State (https://www.diyaudio.com/forums/solid-state/)
-   -   Problem with my audio amplifier (https://www.diyaudio.com/forums/solid-state/368266-audio-amplifier.html)
Niko58 22nd February 2021 04:47 PM
Hello, I recently designed a power amplifier with capabilities of around 120W. The problem came as I connected the speakers and turned it on. What happened was the speaker started moving and making noise without any input signal. I also measured the voltege between speaker terminals and my multimeter showed the same voltage that was on the positive output of the power supply, sience Im using dual polarity type psu.
I hope someone here has some insight on the topic, it would be really helpful.
as_audio 22nd February 2021 05:27 PM
I am afraid you did not tell us enough to be helpful..
Michael Bean 22nd February 2021 05:28 PM
Is this a guessing game? Seriously, nobody can shed light on a problem without any relevant info. So what's the design (schematic)? How was it built (pictures)? What were the specific test conditions? Etc.
It's the equivalent of "I made this thingamajiggy and it doesn't work...tell me what's wrong" without providing anything to go on.
Mike
as_audio 22nd February 2021 05:34 PM
His second post, so please be patient.
Michael Bean 22nd February 2021 05:42 PM
I was patiently explaining why that post would not get the desired results. ;)
Mike
rayma 22nd February 2021 05:55 PM
A new DIY amplifier should always be checked with test equipment first, before connecting speakers to it.
Especially if it is a new design, and not a kit. The speakers can be damaged otherwise.
adason 22nd February 2021 06:00 PM
Quote:
Originally Posted by Niko58 (https://www.diyaudio.com/forums/solid-state/368266-audio-amplifier-post6544504.html#post6544504)
dc on the output the same as positive power supply should never be connected to the speaker
its likely some dead transistor
as_audio 22nd February 2021 06:06 PM
In that case the woofer will be dead.
adason 22nd February 2021 07:46 PM
120 watt amp is probably running +/-45 volt supply, or higher, typically
niko58 did not share that with us
that would make woofers membrane jump on the floor
when I test new amp (i do not design any, just copy), I use cheap small fullrange, even that often cap protected
we need pictures, niko58, post lots of pictures
Niko58 23rd February 2021 07:57 AM
Its runing on +/- 60V, Im using dummy speakers so no worries about blowing them up. Ive came to the same conclusion that one of the lateral MOSFETs probbably SJ162 is faulty.
Ive measured Source to drain about 200, then I went and measured drain to source and both of the two PMOS Im using started filling up, one of them came to the value of 2000 and then showed an open circuit, however the other one didnt. It just stayed rock solid at just below 2000.
This doesnt seem okay to me, but Im no pro so thats why Im here.
Hope you can tell me something with the data I gave you.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
