diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Subwoofers (https://www.diyaudio.com/forums/subwoofers/)
-   -   Dayton 15" IB in W-baffle (https://www.diyaudio.com/forums/subwoofers/366403-dayton-15-ib-baffle.html)
Mayday 19th January 2021 10:29 AM
As the topic says. I'm looking to use my two Dayton 15" IB in as small an configuration as possible.
I don't need them to go below 35Hz and I would like to have them roll off at around 100Hz or so.
I have a couple of populated and tested FreeDSP classic boards and the means to program them via Sigma Studio.
I also have an unmodified DCX2496 (version with memory card slot).
I can use EDA's, decent at simulation SW but know very little about loudspeaker design.
esl 63 19th January 2021 03:46 PM
Plezze sell them to me. I need two more in my setup. :-)
Mayday 20th January 2021 08:48 AM
Nobody?
Anyone who can tell me in what, small, configuration these sound good?
esl 63 20th January 2021 11:03 AM
So what is the real question?
Mayday 20th January 2021 12:20 PM
The best, small, OB/W-baffle.
Preferably a design, design plans.
TBTL 20th January 2021 01:08 PM
What have you found yourself?
Mayday 20th January 2021 01:17 PM
Not much as I've got limited time looking with chronic pain and a 4-year old daughter.
norman bates 21st January 2021 10:16 PM
Well, i bet you will need bass boost to get down there.
Not many infintite baffle / open baffle fans here.
I had a qts .4 12" with fs of 50hz in an open baffle with 2' deep wings.
A buddy here tested his of same dimensions and the math worked out.
Dip 280hz, peak at 140hz, then rolling off below that.
I know it is not what you are asking, but my rip buddy wanted to try those 2 drivers in a bandpass......
TBTL 22nd January 2021 07:51 AM
Infinite baffle subwoofer drivers are an excellent choice for a dipole subwoofer.
The dimensions of a W frame are not critical. Make sure the magnet vents are free to breathe and that the cone does not hit anything. Narrow slots (cross sectional area much smaller than Sd) effectively add cone mass which reduces fs and increases Qts. This can be beneficial if you want to use the subwoofer below its natural fs. I would avoid it as fs already is 21.5 Hz. The slots exhibit a parasitic 1/4 wavelength resonance which should be above the passband of the subwoofer, so slot depth should not be too large. On the other hand, a larger depth spaces the front and rear of the dipole further out, which increases efficiency which is good.
In practice, W frames usually are designed such that the woofers barely fit and the slots have a cross sectional area of about Sd. It is OK to stick the magnet through a panel, as is done in most 'ripole' subwoofers.
Example: SLS Ripole Subs - DIY Audio Projects - StereoNET
One of the woofers can be flipped to cancel out even order components of the harmonic distortion. This however does not affect odd order distortion components, which are more offending to the ear. Some people say that even order components sound pleasent and should be left in place.
Example: Dipole Woofer
You would need a microphone which is flat between 20 and 1000 Hz to measure the frequency response of the finished subwoofer, so you can determine what equalization is required.
Mayday 23rd January 2021 07:53 AM
Quote:
Originally Posted by TBTL (https://www.diyaudio.com/forums/subwoofers/366403-dayton-15-ib-baffle-post6498925.html#post6498925)
Thank you :)
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
