[Advice Needed] DAC Balanced output filters + Gain stage
I want to add balanced xlr outputs to my DIY CS4398 DAC.
I am honestly a little clueless in my design choices, so any advice would be appreciated.
Mainly: Is this the right way of doing balanced volume control using opamps?
Secondary: I plan on adding a relay to pull the signal to ground to mute (see the flags labeled 'mute' near the volume control pot). However with this method will leave the signal trace on the pcb open when not muting and I'm worried it will work as a nice little antenna for EMI.
The output filter stage is taken directly form the CS4398 datasheet.
I've also added a screenshot of my current progress with the pcb layout. Something got messed up with the component annotations, so these might not correspond with the ones in the schematics.
