diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (https://www.diyaudio.com/forums/tubes-valves/)
-   -   Lifting centre tap for B+ delay (https://www.diyaudio.com/forums/tubes-valves/360235-lifting-centre-tap-delay.html)
hariadi88 15th September 2020 11:42 PM
If I have power trans with full wave rectifier, is it possible (and safe) to put switch between centre tap of secondary and ground to delay the B+?
I know ther is more proper B+ delay circuit out there, but I prefer the simplest one (albeit manual).
Any simpler way? Use Thermistor instead of switch?
Thanks in advance
audiopro 16th September 2020 12:26 AM
Guitar amp manufactures have been doing that for decades. It's called a standby switch.
rayma 16th September 2020 12:44 AM
Right, but still use a quality switch rated at a reasonable AC voltage.
dgta 16th September 2020 12:59 AM
Tube PA amps did the same, although some didn't just open the circuit.They had a resistor across the switch so when open (stand by) there is a high resistance from the CT to ground. I believe this is a better arrangement.
hariadi88 16th September 2020 01:12 AM
Thanks guys,
Btw, what is the resistor value around? a few kOhm? or hundreds Ohm enough?
Would the full current draw pass through this resistor, ie need high rating?
rahew 16th September 2020 08:18 AM
Hi
If it helps my Racal RA17 receiver uses a 10 k 10watt resistor in standby (About 370v DC across it in standby)
Robert
6A3sUMMER 16th September 2020 08:36 AM
rahew,
I often forget details, as do we all.
P = E(squared)/R
370VDC and 10k = 13.7 Watts!
A 10 Watt resistor will smoke!
Or at least melt the insulation off a wire that is too close.
Prevent Forrest Fires.
Ketje 16th September 2020 09:25 AM
Quote:
Originally Posted by 6A3sUMMER (https://www.diyaudio.com/forums/tubes-valves/360235-lifting-centre-tap-delay-post6343055.html#post6343055)
rahew,
P = E(squared)/R
Only in the case if the 370V positive is shorted.
I think 10W will do fine.
33k / 5W is another possebility.
Mona
Merlinb 16th September 2020 10:44 AM
I've used 47k to 100k 2W without problems. Depends how much current the amp sucks during the 'standby condition', of course.
dgta 16th September 2020 04:59 PM
Quote:
Originally Posted by Merlinb (https://www.diyaudio.com/forums/tubes-valves/360235-lifting-centre-tap-delay-post6343130.html#post6343130)
... Depends how much current the amp sucks during the 'standby condition', of course.
And that depends on the resistor you place across the standby switch :)
Last PA amp I looked at was a 50W amp and it had 3k@5w across the standby switch.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
