diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   PC Based (https://www.diyaudio.com/forums/pc-based/)
-   -   Simple DLNA Renderer for Odroid C1+...or not? (https://www.diyaudio.com/forums/pc-based/360173-simple-dlna-renderer-odroid-c1.html)
masterkw 14th September 2020 04:15 PM
Hello,
I'm Oliver from Germany and it's my first post.
First of all please be patient if I don't succeed in getting to the point. I'm a "digital audiophile" and my perfect setting for listening music is:
[NAS] ---USB A-B---> [AMP]
Basically this works fine and is the straightest signal way from NAS (Synology DS716+II) to amp which is capable to handle digital audio files up to DSD256 (Audiolab M-One). Server app is "Synology Audio Station", transcoding disabled, bitperfect and gapless playback.
The problem: after an indefinite period of time (sometimes on from beginning) the amp looses input signal and I have to pull the USB plug once to reactivate the connection.
A solution: runeaudio on Odroid C1+ with network source ...as a kind of "technical middleware" and it keeps up connection. ;)
Well, runeaudios library gui is quite nice and clean but DS Audio is a little more comfortable.
A solution is to activate UPNP/DLNA in runeaudio.
[NAS] ---RJ45 (DLNA)---> [runeaudio] ---USB A-B---> [amp]
Works, too. Problem: no gapless playback using Audio Station/DS Audio (iOS)
I have no idea about Linux but I've heard something about a lightweight distribution with MPD and upmpdcli - instead of runeaudio ('oversized') - could be a solution. Could it?
If everything is too complicated, I'll stick with runeaudio as a player.
edit
I just used Volumio for comparison, no improvement here either so I think it won’t work with other linux MPD solutions. Am I right? Any other ideas?
Regards,
Oliver
phofman 14th September 2020 07:49 PM
Synology DS716+II is a linux computer (Intel Celeron N3160) running some old kernel with lots of backported patches. Even if synology guys backported newer alsa fixes for usb-audio class 2, I doubt they did it clean and fault-free. Very likely the alsa usb-audio driver is in a very sad state compared to modern kernel. Most likely runeaudio runs a newer or better-backported kernel which fixes some bugs/suboptimal support.
Yet perhaps a peek at system logs via ssh connection to the synology box could reveal the real cause and perhaps it could be fixed externally without upgrading the kernel (which is unfeasible, AFAIU).
linuxfan 15th September 2020 01:16 AM
Quote:
Originally Posted by masterkw (https://www.diyaudio.com/forums/pc-based/360173-simple-dlna-renderer-odroid-c1-post6341240.html#post6341240)
Yes, mpd is simple and reliable.
You could install a "standard" Linux distribution on your Odroid, then manually install and configure mpd.
But if you prefer a pre-packaged distribution for Odroid with mpd ready to go, I think Archphile would be your best option -
Archphile - Browse /odroidc2 at SourceForge.net
linuxfan 15th September 2020 02:46 AM
Updated link for the latest Archphile for Odroid C1/C2 -
Archphile - Browse /odroidc2/1.19-beta-corona at SourceForge.net
masterkw 15th September 2020 05:24 AM
Thank you for your replies.
With DSM 6.2 Synology has officially discontinued USB - DAC audio. If it still works, fine but no support. So I would go on with Odroid basically.
I‘d prefer a pre-package as well. ;) I'll test Archohile and I'll get back to you.
The most important thing for me is a bitperfect data output. Okay, and a good operation gui.
linuxfan 15th September 2020 06:16 AM
Quote:
Originally Posted by masterkw (https://www.diyaudio.com/forums/pc-based/360173-simple-dlna-renderer-odroid-c1-post6341785.html#post6341785)
Archphile is probably configured for bit-perfect audio. You can check the Archphile author's comments here -
Archphile - An Archlinux Based Audiophile Distribution for Raspberry Pi and Udoo Quad
And you can also check the configuration of ALSA and MPD which I explained here -
https://www.diyaudio.com/forums/pc-b...ml#post5010872
... and a good operation gui.
There are many different MPD client applications available. Some are good, some not so good.
For Android I like MPDroid
MPDroid – Apps on Google Play
and MPD Control
MPD Control – Apps on Google Play
masterkw 15th September 2020 01:32 PM
I've successfully installed Archphile on mSD but no "sign of life" with the C1+. I did a little browsing on Mikes blog and found out that he has dropped C1+ support in 2018 and still went on with C2.
As already said I have no idea about linux but I'm willing to try if anyone can show me "the first steps into right direction".
On odroid-wiki I found that: odroid-c1:os_images:third_party [ODROID Wiki]
Which should I take and what do I have to configure for "DLNA-in - USB-audio out to amp"? (...controlled by Synology DS audio app).
BTW, I'm on macOS 10.15...keyword: ssh.
linuxfan 15th September 2020 03:54 PM
Quote:
Originally Posted by masterkw (https://www.diyaudio.com/forums/pc-based/360173-simple-dlna-renderer-odroid-c1-post6342167.html#post6342167)
Ah, the version of Archphile that I suggested (ver 1.19) may be too new.
So try version 0.99.73 from 2018 -
Archphile - Browse /odroidc2/0.99.73-alpha at SourceForge.net
Forget about DLNA. MPD is more than just an endpoint/renderer, it's a full music server. So your Synology NAS will go back to its conventional purpose of just being a network fileshare. The Synology DS Audio app is no longer in use.
USB-audio out
Linux will auto-configure a USB audio device. Just make sure that your DAC (which I understand is internal to your amp) is turned on first, before powering up the C1.
masterkw 15th September 2020 07:57 PM
Archphile seems to be a dead end street for the moment. The last official build is 0.99.4b and I couldn't find any download link for this older version.
PS: tuxx got a pm
What can I try meanwhile? I've several mSDHC for testing purposes.
CharlieLaub 15th September 2020 08:11 PM
I used MPD for several years before dismantling everything for a move about 2 years ago. It works well for local file playback. What seemed to be very much lacking was some kind of streaming audio support. How do I play tunes from internet radio, Pandora, Spotify, etc?
I strongly prefer not to install a dedicated distro like Volumio on any of my machines. Instead, I'm thinking of exporting the desktop or a web browser window from my "server" to a portable control client like an Android tablet since most if not all streaming audio services are web based.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
