diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Class D (https://www.diyaudio.com/forums/class-d/)
-   -   Allo volt+d custom powersupply, and am questions (https://www.diyaudio.com/forums/class-d/359786-allo-volt-custom-powersupply-am-questions.html)
Xqzme 6th September 2020 10:53 AM
Hello!
I've just bought the Volt+d, and will be using it with my B&O RL60.2(so far so good).
I'm not the biggest fan of the translucent case it comes in, and would rather make a nice wooden/brass box to fit it inside. I'm also considering making an on/off switch, and put in a nice toroidal ring transformer I have salvaged from some quality gear, which both have a 12v and 24v output.
My question is, could I connect the transformer right to the amp, or should I put anything in between ?
Would a toroidal transformer be better or worse than a laptop power supply?
Should I shield the amp from the transformer ?
And finally, how would I know which settings I should use for the AM bandwidth avoidance circuit..
Yatsushiro 6th September 2020 11:02 AM
A transformer provides AC voltage, your amp requires DC voltage; do not connect them directly.
Xqzme 6th September 2020 11:05 AM
Thank you, could probably have found out looking at the transformer first.. Anything important to look for in a conversion module ?
Yatsushiro 6th September 2020 11:32 AM
You need a full wave rectifier, but need to watch out for ripple and rectified peak voltage (The Volt +D has an absolute max of 30v)
Someone far more knowledgeable than me will come along shortly, but in the meantime:
Full Wave Rectifiers | Electrical4U
Xqzme 6th September 2020 11:44 AM
Thank you Yatsushiro, that was some of the most educational I have read on a Sunday!
jasonhanjk 7th September 2020 02:14 AM
The no load peak voltage after rectify must not exceed 30V. You need a scope to check it.
Otherwise just get a 24V 3A SMPS.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
