diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   The diyAudio Store (https://www.diyaudio.com/forums/the-diyaudio-store/)
-   -   Burson Audio V5i Hybrid Opamp (https://www.diyaudio.com/forums/the-diyaudio-store/356558-burson-audio-v5i-hybrid-opamp.html)
b4bz 27th June 2020 02:53 AM
Looking for a simple and good circuit design for an opamp preamp to go with my ACA that uses the dual "Burson Audio V5i Hybrid Opamp" that just became available on the site. It will need to use the same 24V single rail power supply as the ACA. Volume control not needed as I have that already with my source. Any suggestions? A project with available bare boards would be ideal, but not required. Thanks!
And... a simple and good design for a preamp using the same opamp with a differential input and the usual V+/V- supply. Thanks x2!
I've ordered the opamps already, cause, why not, and also got a number of ne5532's from digikey as guinea pigs.
SSaudio 29th June 2020 04:15 AM
Hello b4bz,
You could use this preamp kit:
Universal Stereo Preamplifier Kit | Jaycar Electronics
With +/-12V power supply, this kit will work well with the V5i dual opamp.
Best regards,
astromo 3rd July 2020 11:33 PM
You might have difficulty sourcing that kit. If you get the SC article you'll get the PCB image, as well. Then it's a case of how good your etching skills are.
One back up plan could be to get Rod Elliott's project 88:
High Quality Audio Preamp
At least the boards are in production.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
