diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Subwoofers (https://www.diyaudio.com/forums/subwoofers/)
-   -   Ciare 18SW Bass Driver use in a BIG Sealed Box? (https://www.diyaudio.com/forums/subwoofers/354939-ciare-18sw-bass-driver-sealed-box.html)
darkmatter 23rd May 2020 01:31 PM
Looking around there are very few 18" Bass drivers that seem suitable for sealed box use, perhaps this one fits the bill? An odd set of parameters though.
Ciare 18SW
Ciare 18.00SW - 18" Subwoofer
This one that is ideal, The McCauley 6174 but is not available in the UK if at all?.
Looking for UK available alternatives which would work in a sealed enclosure.
Thoughts?
chris661 23rd May 2020 01:59 PM
Pretty much anything will "work" in a sealed box. What sort of performance are you hoping for?
Chris
darkmatter 23rd May 2020 02:10 PM
Quote:
Originally Posted by chris661 (https://www.diyaudio.com/forums/subwoofers/354939-ciare-18sw-bass-driver-sealed-box-post6215831.html#post6215831)
Chris
Thanks for your reply.
20Hz or better in room performance is the target, and a 2-300 litre enclosure is not a problem so the device will be big.
I will be building a pair
chris661 23rd May 2020 02:35 PM
Well, here's what a pair of sealed 8"s does in-room:
https://i.imgur.com/23gwOqJ.png
(SPL not accurate)
You don't need big drivers and boxes to get low into the bass, but you do need those things if you want to go loud.
Chris
darkmatter 23rd May 2020 03:38 PM
Quote:
Originally Posted by chris661 (https://www.diyaudio.com/forums/subwoofers/354939-ciare-18sw-bass-driver-sealed-box-post6215865.html#post6215865)
(SPL not accurate)
Chris
Yes worked out that I might get away with 15" at a push, but 18" will be needed to produce the output I require.
chris661 24th May 2020 08:46 AM
Fair enough.
Got any signal processing, and how much amplifier do you have?
Chris
darkmatter 25th May 2020 03:14 PM
Quote:
Originally Posted by chris661 (https://www.diyaudio.com/forums/subwoofers/354939-ciare-18sw-bass-driver-sealed-box-post6216755.html#post6216755)
Fair enough.
Chris
Might use DSP mini or something similar, but got 2 x 1Kw rms 8 ohms
GM 25th May 2020 09:04 PM
Not UK, just a frame of reference; at the allowable net Vb, these will 'loaf' along with little power required, though with plenty of dynamic headroom built in if later desired: HS-24 mkIII 24″ Subwoofer – Stereo Integrity
GM
darkmatter 25th May 2020 09:07 PM
If only
I am limiting my investigations only to drive units easily available in the UK
Richard Ellis 25th May 2020 09:52 PM
Crunching the numbers on WinISD for a ported type, (their recommendation at EBP of 65)....I get a much more extended bottom-end.
Internal volume, 188 Liters
Tuned frequency, Fb, 28.9 hertz
Port, 200mm diameter, 440mm long
-3.06 Db @ 25.95 hertz ....
A much more functional & accurate portrayal of low frequencies...
People up one side & down the other will be saying, a sealed enclosure is superior...trotting out many adjectives, like "tighter"...blah, blah blah, often without documentation to back it up...& likely those differences are beyond our hearing capabilities anyway.
----------------------------------------------------------------------Rick..........
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
