in need of recommendation for a mid-bass driver
What drivers would you recommend for a two-way system with a tweeter going down effectively (94 dB) to 900-1KHz and a little less effectively (90 dB) to 600Hz?
* the driver in question is the Vifa DX25TG05-04 if it makes any difference. price per unit: maximum 65-70 US dollar. thanks Jonathan |
One of the Seas 6.5" - P17rcy would be a good start.
Here are some links that might help:
http://www.linkwitzlab.com/x-mid_dist.htm http://mfk-projects.com/7_in_test.htm |
Not really enough useful infromation to recommend a driver.
The tweeter will excursion limit at the frequencies you mention, generally its crossed over 2KHz or higher. :) sreten. |
What do you think about audax HM170C0?
it has a nice flat, really wide freq range. will it do? |
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by
vB Optimise (Pro) -
Copyright ©1999-2021 diyAudio
