CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.
I would like to announce CamillaDSP, a general purpose tool for routing and filtering sound. It can be used for example for building crossovers for active speakers, or for performing room correction.
You can find the source code here: GitHub - HEnquist/camilladsp There is a second repository for configuration help here: GitHub - HEnquist/camilladsp-config: Help for setting up CamillaDSP, example config files etc Quick summary
I have been using BruteFIR for crossovers for quite some time, but there were two main things I wanted to improve upon. Firstly BruteFIR only supports FIR filters, and I wanted the ability to also use BiQuad without having to make an overly complicated setup. Secondly when BruteFIR encounters a buffer underrun it always exits with a "broken pipe" error instead of just trying again. This can get somewhat annoying. I also thought that the BruteFIR configuration is unnessecarily complicated. I have also been using the excellent tool EqualizerAPO that does all I want, but it's for Windows only. When using Alsa for both input and output, CamillaDSP can work almost as a drop-in replacement for BruteFIR. I run a 2048 tap stereo 2-way crossover at 44.1kHz, and this consumes less than 2% of a single cpu core on my HTPC (dual core Intel Skylake). To help with configuration CamillaDSP checks the configuration and tries to give helpful error messages when there is a problem. In addition there is a Python script to visualize the whole pipeline from a config file. Sample output: https://github.com/HEnquist/camillad...r/pipeline.png To try it, download a pre-built binary for your system from the "Releases" page:. Click "Assets" to view the available files. Instead of using a pre-built binary it can also be built from source. The "Cargo" tool makes this very easy as it will download and compile all dependencies automatically. See more instructions in the README. |
Wow, very impressive! That really looks like a nice piece of work.
Couple of questions: How are you implementing the FIR convolution (e.g. using what library, it was handcoded, etc.).? How do you account for different latencies of different FIR filters, and if you have many filter blocks on one path from input to output versus another path? |
Thanks!
The convolution is done with the overlap-add method and it's using RustFFT for fft/ifft: GitHub - awelkie/RustFFT: A mixed-radix FFT library written in pure Rust The processing is done on chunks of audio data. The capture device captures let's say 1024 frames, and then passes this chunk to the processing thread. This then applies all filtering, mixing etc before passing it on to the playback device. This means that there will always be a delay of 1024 samples, plus a little bit more for the time the processing takes. In this case the fir filter can be up to 1024 taps but no more. For longer filters a larger chunk size is needed. If there are different FIR filters for different channels, they need to be matched so they have the same latency. It would also be ok to add a simple delay to a channel to make up for a shorter FIR latency. I guess that in most cases a crossover will be designed in matched pairs, so there is no relative delay between the high- and lowpass filters. But if you then add a FIR room correction to only the LF channels, the HF will be too early and needs a delay. This isn't done automatically. |
Awesome Work!
One question: Is it possible to NOT use a loopback interface and read stream directly from /dev/stdin and send the output to /dev/stout just like BruteFIR? |
I haven't needed stdin/stdout so I haven't implemented that yet. But I will! Probably quite soon.
Quote:
Quote:
Got it running on a headless Debian / Mopidy / Mopidy-Spotify & File player, easy to configure and handle! Doing convolution with rephase-generated filters.
Great, thank you for this nice piece of software! Jo |
Quote:
Just out of curiosity, how long filters do you have, what samplerate, and many channels are you outputting? And are you using the Alsa backend? |
Filter is 16384 taps, 2 channels, 48khz, running on an Intel Celeron J3160, approx. 5% CPU load. CPU load is pretty much the same than Brutefir, delay is much shorter.
Kr J |
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by
vB Optimise (Pro) -
Copyright ©1999-2021 diyAudio
