diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Car Audio (https://www.diyaudio.com/forums/car-audio/)
-   -   Fault finding on Kicker IX702 (https://www.diyaudio.com/forums/car-audio/34878-fault-finding-kicker-ix702.html)
mr__mcgoo 27th May 2004 06:35 PM
Does any one have schematics for a kicker IX702? or know much about there design? The output stage uses 1 tip36c and tip35c per channel (two channel amp) and the power supply uses 4 k2312's?.
This amp has been on it's way out for a long time, it would over-heat with a 4-ohm load and no input (RCA disconected), had bad distortion at high levels on some days and none on others even playing the same cd. And now it just sounds bad at any level and i cant seem to find the problem.
Please Help,
Sean McGee
mr__mcgoo 29th May 2004 05:44 PM
Today i connected up the amp and it's working again. I felt the transistors and mosfets while at low volume and the SMPS stays cool but the TIP's get hot fast. The voltage from the SMPS is ~31.5 volts +/-. ANY IDEAS?
Sean.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
