diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Elekit (https://www.diyaudio.com/forums/elekit/)
-   -   Has anyone disabled or bypassed the volume attenuator in the TU 8600? (https://www.diyaudio.com/forums/elekit/339614-disabled-bypassed-volume-attenuator-tu-8600-a.html)
Cifte12AU7 26th June 2019 10:48 PM
Has anyone successfully bipassed the volume pot entirely in the Elekit TU8600 amp? Would there be sonic gain from running the amp without the attenuator and using a preamp? I have the need for digital and analog single ended inputs and the Elekit has only one set of inputs. I would ideally like to use the unit as an amplifier only. Currently I either switch inputs manually or use a preamp and keep the Elekit volume at 12 o'clock, adjusting volume from the preamp.
Tromperie 26th June 2019 11:47 PM
What is "sonic gain"?
paczeltf 27th June 2019 09:55 AM
Quote:
Originally Posted by Cifte12AU7 (https://www.diyaudio.com/forums/elekit/339614-disabled-bypassed-volume-attenuator-tu-8600-a-post5835732.html#post5835732)
Has anyone successfully bipassed the volume pot entirely in the Elekit TU8600 amp?(...) keep the Elekit volume at 12 o'clock, adjusting volume from the preamp.
Why do you keep the Elekit volume at 12 o'clock if you want to bypass the pot entirely anyway? It is not a good idea as a logarithmic potmeter drops almost 90% of the input signal in the middle position so you may end up overloading the output stage of your preamp at higher volumes.
Here is a similar thread:
TU8500 + TU8600 - volume position
If I were in the same situation then I would use a passive preamp and a separate RIAA phono unit.
Quote:
Originally Posted by Tromperie (https://www.diyaudio.com/forums/elekit/339614-disabled-bypassed-volume-attenuator-tu-8600-a-post5835779.html#post5835779)
I am not a native English speaker but to me it means something like "sonic benefit" or simply "better sound".
Cifte12AU7 27th June 2019 01:09 PM
Interesting. So do you think I should turn it to it’s maximum setting?
Yes, sonic gain was meant to be better sound.
paczeltf 27th June 2019 02:19 PM
Quote:
Originally Posted by Cifte12AU7 (https://www.diyaudio.com/forums/elekit/339614-disabled-bypassed-volume-attenuator-tu-8600-a-post5836289.html#post5836289)
Yes, at least for the following reasons
a) this is the position that affects the signal quality the least by far
b) the volume attenuator's position has impact on the bandwidth
c) you will get the same volume levels if you bypass the potmeter, which is what you want to do
The only exception to this rule would be a noisy input stage in the amp before the volume potmeter, but the TU-8600 does not have anything like that
Max Headroom 27th June 2019 03:57 PM
Any stages upstream are certain to degrade signal wrt direct connection to TU 8600.
My choice would be to add sockets and a DPDT switch to the rear panel of the TU 8600 and modify the pcb connections....cut two tracks (L&R) and add 6 wires (take care of wire directions).
Running preamp upstream adds extra cables and preamp noise/distortion/colouration which may be subjectively pleasing, but ime direct connection to power amp is best.
If you decide to run the preamp you could replace the amp volume pot with fixed resistors to set fixed gain and you can experiment with resistor types (MF, CF etc) and this will set a 'tone' to the amp that is likely preferable to cheap generic carbon volume pot and would also help in 'perfect' channel matching.
Dan.
planet10 27th June 2019 06:13 PM
I am usually adding a volume (gain) control to my poweramps so that they can easily be used with PLLXO when i biamp. If you are using the TU-8600 as a power amp, turn the volume up all the way and it will effectively be out of the circuit (but for the shunt series R — often used as the gtid resistor for the following tube.
dave
Max Headroom 28th June 2019 02:55 AM
Turning the TU 8600 volume to max will degrade system signal/noise, this is why I suggested replacement with fixed resistors or extra sockets/switch.
Dan.
paczeltf 28th June 2019 11:27 AM
Quote:
Originally Posted by Max Headroom (https://www.diyaudio.com/forums/elekit/339614-disabled-bypassed-volume-attenuator-tu-8600-a-post5836973.html#post5836973)
Why? Is there any active stage before the volume pot? I do not have the schematics of the TU-8600 but I have these for 3 other recent Elekit amps. All of them connect the first stage of the amp to the pot, which receives the signal from the input directly. I doubt the 8600 would be any different.
From a signal perspective, setting the volume to max in such cases connects the input to the first stage of the amp directly and also to the ground via an 50k Ohm resistor. This is how power amps are usually wired, the only difference is their somewhat lower sensitivity compared to the Elekit models.
Adding second input and a toggle switch is fine as long as you are willing to make irreversible changes to the casework and mess up the PCB and have the right tools, and you also accept the inconvenience of a having to use the input switch on the back.
I personally prefer a passive preamp.
Ferenc
Max Headroom 28th June 2019 03:42 PM
I am assuming that the amplifier is setup to provide rated output with standard level input and volume control set at 12:00 with which is -20dB attenuation as per normal practice.
Amp vol control set to 100% therefore causes preamp needs to run at -20dB operating level and this causes loss of system SNR of 20dB at max system output, and worse at lower level system output.
Volume pot can be replaced with fixed resistors in 9:1 ratio to give same sensitivity as 50% volume control and discrete resistors may sound better than carbon vol control.
Dan.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
