diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Full Range (https://www.diyaudio.com/forums/full-range/)
-   -   Alpair 5.2 WAW bass driver size (https://www.diyaudio.com/forums/full-range/338062-alpair-5-2-waw-bass-driver-size.html)
JRKO 18th May 2019 04:40 AM
I’m making a pair of WAW for a friend. We’ve settled on the alpair 5.2 but am unsure which bass assist driver size to use. Cabinets can be stand mount or floor standing.
Looking at SBAcoustics drivers of 5-8 inch sizes which will run downwards from about 300hz. Crossover will likely be PLLXO
Dual opposed drivers is also an option
Are there any rules/benefits regarding certain woofer sizes?
Stal 20th May 2019 06:45 AM
I'm currently building a WAW and have settled on an 8inch bass unit. Monacor SPH 8M. Generally the bigger the better since you are only going up to 300Hz or so.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
