diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Multi-Way (https://www.diyaudio.com/forums/multi-way/)
-   -   Vifa PL14WJ-09-08 Mid Woofer (https://www.diyaudio.com/forums/multi-way/333758-vifa-pl14wj-09-08-mid-woofer.html)
giosblue 10th February 2019 09:10 AM
Any one had any experience with this driver. I've found a kit that uses these and the tweeter I already have. Same size box and there is a crossover to suit.
Ron
cspieker 10th February 2019 04:41 PM
A buddy of mine built a pair of mtm's with the pl18 and a scan speak tweeter. They sound lovely. A bit of a chesty coloration at about 800hz, but it's subtle and they're otherwise excellent. Not sure if that helps you at all. I'd certainly take a shot on its little brother if it was me.
rabbitz 10th February 2019 11:23 PM
The PL series are excellent drivers. I've used the PL11 in the past with good results.
IMO you have nothing to lose in trying it.
There's a comment about the PL14 here.
Vifa PL14WJ-
Lojzek 11th February 2019 09:17 AM
Better check their free air impedance profile to be sure the suspension is in acceptable condition for bass performance.
system7 12th February 2019 01:51 AM
It's quite a bassy little driver, according to Troels Gravesen:
Vifa PL14WJ-
Because it is relatively inefficient. 5" paper cones can sound a little unforgiving to my ears.
A polycone Peerless 830860 looks a good unit too:
Peerless HDS PPB 830860
Either way, a bedroom speaker really. Won't go loud. Not a lot of bass. Maybe 15L is better.
badman 12th February 2019 01:18 PM
Vifa PL (and in general, it's a house-sound kind of thing for the most part) are great drivers with a very listenable character. I rather like when drivers can be played widerange without nasty breakup, because even good crossovers can't mitigate ALL ringing.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
