diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   PC Based (https://www.diyaudio.com/forums/pc-based/)
-   -   web-based audio library that can stream to DLNA? (https://www.diyaudio.com/forums/pc-based/333739-web-based-audio-library-stream-dlna.html)
daemonsgr 9th February 2019 05:13 PM
At the moment I have all my FLAC in a Synology.
I also have two DLNA streamers (Neet aristream and my Denen AV Amp).
Synology gives you a media server and a really bad 'audio service' which is a webapp for streaming and library management. I tried to use it with my Neet streamer and it didnt work. Its also bad when it comes to searching for things.
So, Im looking for alterantives:
1) with a web interface that can use a existing ynology DLNA db or even build a new one from a shared folder
2) manage, search and play flac etc (like an itunes on web)
3) play the audio through the DNLAs ___not___ "locally" or "via the browser"
4) linux or docker based please! Daphile for example is cool but can only use DACs attached to the systems (right????)
Thanks!
wealas 9th February 2019 07:49 PM
Minimserver?
DRONE7 9th February 2019 09:31 PM
OpenMediaVault ?
OpenMediaVault - The open network attached storage solution
Yatsushiro 10th February 2019 03:13 PM
Quote:
Originally Posted by daemonsgr (https://www.diyaudio.com/forums/pc-based/333739-web-based-audio-library-stream-dlna-post5692098.html#post5692098)
Thanks!
You need to look at Daphile again; as it essentially is an LMS, you can use the LMS upnp/DLNA plugins to stream to your DLNA devices
Alternatively, you could run LMS directly on your Synology.
Have a look over here for more information:
Squeezebox : Community : Forums
This thread in particular may be a good place to start:
Synology 7.9.2 packages
daemonsgr 10th February 2019 09:50 PM
Thanks ill look at it again. Lms runs but a) looked older than me.. b) the drop menu for streamers only included the squeezy things. (True?)
Yatsushiro 11th February 2019 11:07 AM
Quote:
Originally Posted by daemonsgr (https://www.diyaudio.com/forums/pc-based/333739-web-based-audio-library-stream-dlna-post5693401.html#post5693401)
The original LMS skins are quite archaic (being designed and developed sometime ago), but you need to use the latest 'Material' skin, developed by an LMS user. This skin works on all PC browsers, Android & iOS devices (phones, tablets etc) and automatically chooses the best layout for PC, phone, tablet etc.
I don't stream to anything other than RPi and chromecast players, but I would imagine once the correct plugins are installed and configured, all available players will be displayed and can be selected.
For the sake of a download and a bit of configuration, give it a go, it's free!
Alternatively, if you want to pay for something very similar, have a look at max2play, which is an 'enhanced LMS', for which the base install is free, but additional functionality has to be purchased.
Max2Play | Audiophile Music and Video Player, Headless Setup Raspberry Pi and Odroid
daemonsgr 13th February 2019 07:53 AM
Wow lms does a ton of things!! I got it working but play stops on every song :s
daemonsgr 13th February 2019 08:24 AM
I have added the DLNA plug and both denon and neet airstream work but stop on every song :S Any ideas?
Yatsushiro 13th February 2019 08:47 AM
Well done on trying it out, and persevering - it will be worth it.
I don't use any DLNA streaming, so don't have your problem, nor have I experienced it on any of my devices.
As you may have seen, LMS is extremely configurable, so perhaps you have missed a setting (perhaps in the upnp/DLNA plugin itself) or have a conflict somewhere.
Can I suggest posting your question on the slimdevices forum?
Edit: Looks like someone else is having a similar problem? uPnP/DLNA Media Interface: playlist stops after one song
daemonsgr 13th February 2019 09:36 AM
I was actually looking at the same post before seeing your reply. Tried to register and waiting for the admin to approve it. A pi spdif hat is arriving today so I can test picoreplyer too...even though it seems redundant if I already have DNLA.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
