JL audio 500/1v2 power supply problems.
I just got a jl audio 500/1 that had two burnt up power supply mosfets. I replaced all of them with 3205's and 47ohm gate resistors. However, the amplifier still just draws current the none, current to none. And then power supply fets heat up as well. Maybe driver transistors.
+-14v on the op amps and I have a drive signal on the q612 gate, 12v on the drain. 5v regulated. I could use some help.
The rail voltage at the 4r7 resistor is all over the place. What voltage should I have at t601? So the 80v of rail is not at the torrid either. It is speratic, on the other 500/1v2 I have I have 80v of trail there. I don't know which one is correct since nether are working.
