diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Analogue Source (https://www.diyaudio.com/forums/analogue-source/)
-   -   Technics sp 10 speed issues ! (https://www.diyaudio.com/forums/analogue-source/326353-technics-sp-10-speed-issues.html)
Retrosoulman 20th August 2018 09:35 AM
Hello!
i got a Technics sp10 mk2 p/l (bbc version). The turntable and the psu have been recaped some months ago, the psu adjusted on the correct voltages and also there are not ripples to them, the motor is oild and the turntable looks in very good condition generally. The problem is that after 1,5 - 2 hours the psu gets really hot and the speed of the turntable gets unstable. I send the turntable back to my technician to solder again some joints on the psu to be sure that everything is ok but still the problem remains. The turntable loose its speed lock after some hours. Does anyone had the same problem with his sp10? Best regards!
billshurv 20th August 2018 11:05 AM
There is a whole SP10 restoration thread here. The Incredible Technics SP-10 Thread
Have a read then ask there.
Edit: I see you have. I would bump that thread as it would be seen.
Retrosoulman 20th August 2018 11:58 AM
Quote:
Originally Posted by billshurv (https://www.diyaudio.com/forums/analogue-source/326353-technics-sp-10-speed-issues-post5521347.html#post5521347)
Thank u!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
