diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   AKSA (https://www.diyaudio.com/forums/aksa/)
-   -   My Aksa (original) has given up (https://www.diyaudio.com/forums/aksa/325564-aksa-original.html)
mingdao 29th July 2018 08:39 PM
Hi all. Hi Hugh!
I used to lurk in these forums in late nineties. Then work and family took over. My original account is long lost, but some things remain from that age including couple of amps that I had built with my own hands.
One of them, which was built in 2001, if I recall correctly, is Aksa original amp.
One channel gave up and no longer works. I suspect blown transistor in the first stage, since it gets smoking hot (circled red in the pic). I've actually burned my fingers pretty bad.
https://i.imgur.com/pnIFrXc.jpg
I do not have any plans for the thing, or a part list.
I am contemplating whether it is possible to revive it without a major effort.
Any ideas what may wrong and what is the part that I need.
Does it have to be matched pair (L/R)?
Many thanks.
Bigun 29th July 2018 09:46 PM
Is that even an original AKSA board or a DIY copy ? It looks like it's caked in dirt and dust and really should be cleaned up or it's just a bad photo.
Blown transistors usually don't run hot, either because they are open circuit (no current) or dead short (no voltage), the problem is possibly elsewhere. Are both fuses OK? Is there a voltage at the output ? Can you measure any of the operating points - voltages around the circuit.
AKSA 29th July 2018 10:01 PM
That's an original AKSA, Bigun! Thank you for your post.
Mingdao, if the voltage amp is running hot it likely means that the npn output device, C1302, is blown. Measure the voltage from the positive rail to the emitter on that transistor; if it is less than 1V, it's your man. Replace it and the amp will sing again!
Hugh
saf 2nd August 2018 09:08 AM
I have to say, without wanting to be offensive, that is probably the dirtiest ugliest looking AKSA i have ever seen.... Clean that up Dude !!!Please !
AKSA 2nd August 2018 09:22 AM
The man speaks the truth....... naughty, naughty. Your amp looks like a porn star.......
Start with compressed air, then start with isopropanol, which does not leave a stain.
I would suggest you take it from the heatsink too to remove the dust around the output stage. I have a feeling the npn output device (2SC5200) is blown, so you might need to change it, or both in fact, the pnp as well. Can't hurt!
Hugh
Bigun 18th September 2018 12:54 AM
Quote:
Originally Posted by AKSA (https://www.diyaudio.com/forums/aksa/325564-aksa-original-post5505572.html#post5505572)
Start with compressed air, then start with isopropanol...
Thatís no way to treat an actress!
AKSA 18th September 2018 03:30 AM
True enough...... but in that industry, Gareth, she might quite like it?
Hugh
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
