diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Elekit (https://www.diyaudio.com/forums/elekit/)
-   -   Another New Product from Sunvalley (https://www.diyaudio.com/forums/elekit/324872-product-sunvalley.html)
vkung 10th July 2018 09:35 PM
Sun Valley SV-Pre1616D
WE will start to accept pre-order in Early August
https://s25.postimg.cc/9yb9yw9rz/022...652573c9f3.jpg
https://s25.postimg.cc/3km6vnkbj/022...6525699d09.jpg
https://s25.postimg.cc/e7g01306n/022...65255f3c5c.jpg
https://s25.postimg.cc/t3ej8ojb3/022...65257df5b7.jpg
- 12 AX 7 JJ ECC 82/12 AU 7
- 12 AX 7 GD 12 AU 7
- Mullard CV 400/12 AU 7 (3 matched) SOVTEK 5 AR 4
You can use the following combination
① 12 AX 7 - 12 AX 7 - 12 AX 7 (Sharp and high contrast)
* Standard combination (SV - 722 Marantz type and same circuit)
② 12 AX 7 - 12 AX 7 - 12 AU 7 (Skeletal feeling and entity feeling of medium low range)
* SV - 722 Mckin type sound image Reproduced
③ 12 AU 7 - 12 AU 7 - 12 AU 7 (round and resonate rich)
※ Featuring a rich overtone feeling of the SV - 310 series
Input: 4 lines [Input 4 can be changed to USB input (option)]
Input Volume: Yes
frequency response: 15 Hz ~ 70 kHz (-3 dB)
gain: 15 dB
size: 250W, 225D, 135H (mm ) ※ including protrusions
weight: 3.6 kg
https://s04.flagcounter.com/count/hZ...ews_1/flags_1/
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
