Output stage capacitors
which capacitors sound best for output stages
Check, you doesn’t ask about which capacitors are needed for OPS, what caps parameters are meaningful and why, how OPS must be designed and routed, why caps have such an influence to sounding and are there a ways to eliminate this.
There are a complicated couple of questions and having no answer to any of them will disable your way to a goal.
As a coupling capacitor for analog Solid state output stages. Googling brings up a few sites where audiophiles have tried a diverse range from VCAPs to Vishay Roedersteins. I'm using 100uF 63V caps, they are back to back electrolytics. Sure there are several types like polyprops etc that would be an improvement.
