diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   PC Based (https://www.diyaudio.com/forums/pc-based/)
-   -   Raspberry PI 2B or 3B - are there audio (sonic) differences? (https://www.diyaudio.com/forums/pc-based/321926-raspberry-pi-2b-3b-audio-sonic-differences.html)
Unkgd 26th April 2018 06:24 PM
I have a couple of spare RPI 2B boards sitting around.
Looking at configuring a couple of streamers for other rooms. My question is when using an RPI and its I2S bus as an audio streamer source (no hdmi, BT or WIFI) are there any sonic differences between the RPI 2B vs 3B?
I normally use either MOode or PicorePlayer as the rendering software.
TIA,
Bill
grimberg 26th April 2018 10:00 PM
A little over 2 years ago I posted some comments about using the the Raspberry Pi to play FLAC files. You may find the information useful.
http://www.diyaudio.com/forums/pc-ba...ml#post4256393
Since then I have switched to Raspberry Pi 3B which is able to play FLAC files of any resolution flawlessly.
anadigi 27th April 2018 12:31 AM
Quote:
Originally Posted by grimberg (https://www.diyaudio.com/forums/pc-based/321926-raspberry-pi-2b-3b-audio-sonic-differences-post5416614.html#post5416614)
Recently, I installed the Picoreplayer V3.50 and is perfect. I am very happy can bring this good soundcard back alive. Flac files are no problem.
Man in a van 27th April 2018 09:36 AM
Quote:
Originally Posted by anadigi (https://www.diyaudio.com/forums/pc-based/321926-raspberry-pi-2b-3b-audio-sonic-differences-post5416711.html#post5416711)
Yep, a plus one from here too.
Just last week I ordered an original wolfson board and connected it to my sole remaing RP1B.
There is a new driver for the card included in Raspbian (it's been there a while I believe).
As stated by anadigi picorePlayer works really well.
The old board can be used with a later model pi
Connecting the Wolfson Sound Card to the Raspberry Pi3 | Life, the Universe and Engineering…
I have also tried it just using Squeezelite as a player and it performs fine. I need to make a start file to make it easier but time is a bit short.
Also used it with the OMXplayer (just audio) in Raspbian.
Omxplayer - eLinux.org
Ronnie
badboygolf16v 29th April 2018 01:02 PM
I have never noticed any difference in sound quality.
If you want to do SRC or format conversions then obviously a 3 is the way to go.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
