diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Full Range (https://www.diyaudio.com/forums/full-range/)
-   -   Cooking my speaker drivers (https://www.diyaudio.com/forums/full-range/321788-cooking-speaker-drivers.html)
mexican 23rd April 2018 12:26 AM
I just want to keep the original spider and surround. make some adjustments and recone.
In a pan for 5 minutes full heat with a cover,
Danger: Neodymium must lost magnetism, Use this recipee at your own risk,
YouTube
works only with a few drivers, I just overcooked 4 of them and not eatable now, BE CAREFUL !!!
adason 23rd April 2018 01:04 AM
That's insane.
While ago, when i had an old fullrange rubbing the coil, i had my own procedure to fix them. I removed dust cap, allowing me access to the voice coil and magnet gap, i inserted voxed paper, you know the one which holds you cassette tape stickers, or march of pennies address stickers, then gently moistured the cone and spider, making it all loose...then let it dry for few days. Once voxy paper removed, voice coil naturally stays in right place centered, mostly.
mexican 23rd April 2018 01:15 AM
good one!
Art M 23rd April 2018 01:16 AM
Quote:
Originally Posted by mexican (https://www.diyaudio.com/forums/full-range/321788-cooking-speaker-drivers-post5413147.html#post5413147)
Danger: Neodymium could lost magnetism, Use this recipee at your own risk,
YouTube
YouTube ?????????????????????
Soldermizer 23rd April 2018 01:55 AM
Being Mexican, how did you season it? :clown:
mexican 23rd April 2018 02:05 AM
chili, garlic, chili, onion and chili and if you want, more chili.
do not forget salsa, with chili
JMFahey 23rd April 2018 03:24 AM
It works on *some* speakers, but you canīt modify much, if anything at all (besides recentering if that was the problem).
Often spider to frame, cone edge or suspension to frame and cardboard gasket to cone edge are glued with white vinylic carpenterīs type glue, which can redissolve in boiling water.
What you did.
But sadly you will not be able to dissolve voice coil to spider and cone joint because on modern speakers itīs either Epoxy or sometimes some kind of thick Krazy Glue (cyanoacrilate),so you will not be able to "mod" anything, only recone with all fresh components.
In any case, congratulations for having rediscovered this on your own.
When I was a kid (think the 60īs and early 70īs) , cheap speaker factories kept large vats which they filled with speakers to be repaired and very hot water ... next day they could safely separate *all* components, including voice coils, because the "universal" glue used everywhere was vinylic.
But those were cheap 5 to 15W speakers, so white glue was enough.
benb 23rd April 2018 04:35 AM
YouTube
Good info can be found by googling:
curie point
Perhaps add the specific magnet type and you may get some info on what temperature to stay under.
chrisb 24th April 2018 12:42 AM
adason - voxed paper?
phivates 24th April 2018 01:37 AM
Yes thanks for asking
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
