diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Pass Labs (https://www.diyaudio.com/forums/pass-labs/)
-   -   Firstwatt DIY in same box B5, ACA, new Pre amp? (https://www.diyaudio.com/forums/pass-labs/321416-firstwatt-diy-box-b5-aca-pre-amp.html)
jonparkhurst 13th April 2018 01:07 PM
As we get to the new DIY kits coming out and thinking of new monstrosities, is it possible (or just dumb) to think of an effiencet way to put a OB xo (B5), ACA or other, and a B1 w/ gain in the same enclosure?
Can I use the same linear ps inside? Would this cause more issues than good.
Thoughts?
P
vdi_nenna 13th April 2018 01:23 PM
There are advantages to separate components.
No reason why you can combine all in one box.
Remember you will need 4 channels of ACAs.
First get all the components before settling on a chassis.
Shoehorning boards into a case after the fact is not fun.
jonparkhurst 13th April 2018 01:57 PM
I would need two ACA why? I missed something..
Nevermind.. I see it now.... duh
vdi_nenna 13th April 2018 02:03 PM
you said you were using the B5. It's a 2-way crossover.
Unless you are listening to mono, you will need 4 channels. ;)
jonparkhurst 13th April 2018 02:05 PM
yes, four out of b5 need a high and low freq amp.
Yup...
adason 13th April 2018 02:09 PM
ACA is great for mids and tweeters, but will likely fail to power OB woofers.
(I use ACA to power my he1000 v2 headphones, the best headphones amp I heard)
Better use some powerful class AB amp for woofers. Even lm3886 would do.
jonparkhurst 13th April 2018 02:11 PM
I'll just use the b5 out to a orca and your right have to use my sub amp I have now for the ob 15s.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
