Hello,
i have gone through my finished projects, and i offer the following for sale
2 PCBs AEM6000 (100W LATMOS-FET amp for 2SK1058/2SJ162 or EXICON ECX10N20/10P20)
-2oz CU (see attached jpg); inluding all parts marked green in attached BOM (pdf-file) total 66€ -sold-
2 PCB APEX AX11 MKII 1oz CU layout by vargasmongo3435 total 8€ -sold-
100W Ultimate Fidelity Amplifier
2 Bulk PSU 1oz CU layout by Prasi 2,5€ each -sold-
PAYPAL available
Shipment + PAYPAL fees not included, depends on destination.
If interested send me PM.
Best regards
Günni
PAYPAL available
Best regards
Günni
What's the minimum input / output of cap multiplier?
Hi Felipe
i use the single cap multiplier for the CFH7 and the AX-11. With a voltage drop of about 5V , and a supply voltage from 35-40 V, you have to feed in 40-45V rectified voltage. The physical dimensions are limited by the given lead space of the pcb, also you can adopt the use values for capacitors.
the dual cap multplier i use for my amp with +/- 52 V supply voltage with a 15000µF/63 V input cap and a 150µF/63V the gates of the IRFP240/9240
BR
Günni
Hi Günni,
I wanna try for digital +5V?
TIA
Felipe
Hi Felipe,
the biggest disadvantage at +5V will be the voltage drop of 5V over the vertikal FET. So you will have to spend double of the power at input as what you get on the output. The same for use at filament for example, 6,3V + 5V (voltage drop at FET) at 2 A, you need about 12 V/2A at the input of the Capmu.
BR
Günni
Hi Günni
Can I take 2 pieces of each posted to 4000 Australia.
PCB Juma CapMultiplyer 1oz CU, layout by Idefixes 2€ each
Juma's Easy-Peasy Capacitance Multiplier
PCB Dual CapMultiplyer 1oz CU layout by Prasi 2€ each
Thanks sp
Hi sp
sure is no problem, Remember shipment and fees is about €4,8 additional and there is no insurance and tracking. Will be sent in a big padded letter.
Let me know, if it's ok
BR
Günni
